はじめに
This guide will help you replace the power and volume buttons on your HP 7 1800.
必要な工具と部品
Use a Spudger to open the back panel. Be careful not to break the tabs.
The power button and volume buttons are together as a single piece. Gently pull up on one side and then pull up on the other side to remove the buttons from the casing.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
