メインコンテンツにスキップ
HP 2000 - 2D22DX Hard Drive Replacement
必要な工具と部品
  1. HP 2000 - 2D22DX Hard Drive Replacement, Battery: 手順 1、 2の画像 1 HP 2000 - 2D22DX Hard Drive Replacement, Battery: 手順 1、 2の画像 2
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch to the left until the battery is detached from its slot.
    • A distinguishable pop will be heard when the battery is fully released.
  2. HP 2000 - 2D22DX Hard Drive Replacement: 手順 2、 2の画像 1 HP 2000 - 2D22DX Hard Drive Replacement: 手順 2、 2の画像 2
    • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
  3. HP 2000 - 2D22DX Hard Drive Replacement, Hard Drive: 手順 3、 2の画像 1 HP 2000 - 2D22DX Hard Drive Replacement, Hard Drive: 手順 3、 2の画像 2
    • Loosen the Phillips #00 screw securing the RAM compartment cover.
    • The screw is permanently attached to the RAM compartment cover. Do not try to remove it completely.
  4. HP 2000 - 2D22DX Hard Drive Replacement: 手順 4、 2の画像 1 HP 2000 - 2D22DX Hard Drive Replacement: 手順 4、 2の画像 2
    • Once the screw is sufficiently loosened, slowly unclip the RAM compartment cover from its slots in the plastic chassis.
    • When unclipped completely, pull the compartment door out and away from the chassis.
  5. HP 2000 - 2D22DX Hard Drive Replacement: 手順 5、 3の画像 1 HP 2000 - 2D22DX Hard Drive Replacement: 手順 5、 3の画像 2 HP 2000 - 2D22DX Hard Drive Replacement: 手順 5、 3の画像 3
    • Loosen the two Phillips #00 screws that are securing the hard drive compartment.
    • The screws are permanently attached to the hard drive compartment cover. Do not try to remove them completely.
    • Once the screws are sufficiently loosened, disconnect the clips holding the cover in place and slowly pull the cover away from the plastic chassis.
  6. HP 2000 - 2D22DX Hard Drive Replacement: 手順 6、 3の画像 1 HP 2000 - 2D22DX Hard Drive Replacement: 手順 6、 3の画像 2 HP 2000 - 2D22DX Hard Drive Replacement: 手順 6、 3の画像 3
    • Using a spudger, disconnect the hard drive connecting cable. Use a slow, prying motion as if pulling a nail out of wood.
    • Be very gentle with the connecting cable and its respective port on the logic board. Both are very fragile and can be easily damaged.
  7. HP 2000 - 2D22DX Hard Drive Replacement: 手順 7、 3の画像 1 HP 2000 - 2D22DX Hard Drive Replacement: 手順 7、 3の画像 2 HP 2000 - 2D22DX Hard Drive Replacement: 手順 7、 3の画像 3
    • Using your fingers, grab the blue tab on the right side of the hard drive and slowly pull upwards.
    • Lift the hard drive out and away from its socket in the plastic chassis.
終わりに
27 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Conor Most
メンバー登録日: 04/14/14
2,705 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 3-40, Maness Spring 2014 Cal Poly, Team 3-40, Maness Spring 2014人のメンバー
CPSU-MANESS-S14S3G40
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 27
今までの合計 14,815
