はじめに
This guide is for removing and replacing the Optical Disk Drive. The main symptom for a bad disk drive is if your computer is having issues reading disks. Check this troubleshooting topic first before replacing your disk drive.
必要な工具と部品
Start by placing the laptop with its bottom facing up.
Using the Phillips #0 screwdriver, remove the single 7 mm screw that holds the disk drive in place.
Insert new optical drive. To reassemble your device, follow these instructions in reverse order.
ある他の人がこのガイドを完成しました。
