メインコンテンツにスキップ
HP 17-x061nr Hard Drive Replacement
必要な工具と部品
  1. HP 17-x061nr Hard Drive Replacement, HP 17-x061nr  Disassembly: 手順 1、 3の画像 1 HP 17-x061nr Hard Drive Replacement, HP 17-x061nr  Disassembly: 手順 1、 3の画像 2 HP 17-x061nr Hard Drive Replacement, HP 17-x061nr  Disassembly: 手順 1、 3の画像 3
    • With the laptop upside down, remove the battery by hand and the twelve 7.0 mm screws that are holding the back case to the front. Use a JIS #0 screwdriver to remove the screws.
  2. HP 17-x061nr Hard Drive Replacement: 手順 2、 2の画像 1 HP 17-x061nr Hard Drive Replacement: 手順 2、 2の画像 2
    • Peel back the rubber footrests located next to the battery, on the left and right sides.
    • Remove the two 7.0 mm screws underneath the rubber feet using a JIS #0 screwdriver.
  3. HP 17-x061nr Hard Drive Replacement: 手順 3、 1の画像 1
    • Slide the optical drive out and away from the laptop.
  4. HP 17-x061nr Hard Drive Replacement: 手順 4、 3の画像 1 HP 17-x061nr Hard Drive Replacement: 手順 4、 3の画像 2 HP 17-x061nr Hard Drive Replacement: 手順 4、 3の画像 3
    • Flip the computer over and use a plastic opening tool to wedge between the back and front cases.
    • Trace the perimeter of the laptop. Make sure to keep the tool inserted between the front and back cases. You will hear popping sounds as the back case becomes disengaged from the front plate.
    • Flip the laptop over and lift the back case off. Now you have access to all of the internal hardware.
  5. HP 17-x061nr Hard Drive Replacement, Hard Drive: 手順 5、 1の画像 1
    • Locate the hard drive.
    • Using the purple hard plastic tab gently pull the cable tape tab out of the input, located on the left-hand side.
  6. HP 17-x061nr Hard Drive Replacement: 手順 6、 2の画像 1 HP 17-x061nr Hard Drive Replacement: 手順 6、 2の画像 2
    • Carefully peel back the cable tape from the hard drive itself.
    • Pull the shock absorbers from the back of the hard drive casing.
  7. HP 17-x061nr Hard Drive Replacement: 手順 7、 1の画像 1
    • Lift up the back of the hard drive module and gently pull it away from the connection point.
    • Be sure to keep the replacement within the package until you are ready to place it.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Curtis Haley
メンバー登録日: 02/23/18
514 ポイント
3のガイドは作成済み
チーム
Washington State, Team S1-G1, Lobnitz Spring 2018 Washington State, Team S1-G1, Lobnitz Spring 2018人のメンバー
WSU-LOBNITZ-S18S1G1
5 メンバー
5のガイドは作成済み
コメント 1 件
Will this work for HP Notebook - 17-y018ca
hamiltoncomputes - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 1,575
