はじめに
This guide will assist you in replacing the HP LCD Screen. You will need to replace the screen if your screen displays black and white lines over your homepage.
必要な工具と部品
Open the laptop so you can see the screen.
Remove the bezel with firm, constant pressure to create a slight gap between the bezel and screen (plastic outlining of screen) with a plastic opening tool.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
