はじめに
In this replacement guide you will be removing and/or replacing the cooling fan inside of your HP 15-r137wm TouchSmart. The cooling fan is used to cool down internal processors so that the device does not overheat. Also, it prevents dust and other harmful substances from entering the device as it blows air outside the device.
必要な工具と部品
Remove all ten (10) 5.5 mm Phillips #0 screws.
Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
Locate the small connection on the motherboard and disconnect it by slowly pulling it away from the motherboard.
