はじめに
This guide will help you remove and/or replace the CD drive inside of your device. The CD drive simply converts information on the inserted DVD into video and audio. The repair for the CD drive is quite simple once other components are removed.
必要な工具と部品
Remove all ten (10) 5.5 mm Phillips #0 screws.
Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
Slide the CD drive out slowly by pulling it to the right. There are no screws attached, but there is a connection to the motherboard.
