はじめに
In this guide, you will remove and/or replace the audio speakers within the HP 15-r137wm TouchSmart. The speakers are where any audio from your device comes out of. These small, compact speakers can reach between 50 and 90 decibels. Also, the screws which attach the speakers to the housing have shock absorbents so that vibration is not an issue when playing audio.
必要な工具と部品
Remove all ten (10) 5.5 mm Phillips #0 screws.
Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
