メインコンテンツにスキップ
HP 15-r137wm TouchSmart Audio Speakers Replacement
必要な工具と部品
  1. HP 15-r137wm TouchSmart Audio Speakers Replacement, Front Panel Assembly: 手順 1、 3の画像 1 HP 15-r137wm TouchSmart Audio Speakers Replacement, Front Panel Assembly: 手順 1、 3の画像 2 HP 15-r137wm TouchSmart Audio Speakers Replacement, Front Panel Assembly: 手順 1、 3の画像 3
    • Make sure that the device is powered off and unplugged before removing components.
    • Remove all ten (10) 5.5 mm Phillips #0 screws.
    • Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
  2. HP 15-r137wm TouchSmart Audio Speakers Replacement: 手順 2、 1の画像 1
    この手順で使用する道具:
    Anti-Static Wrist Strap
    $7.95
    購入する
    • Use a wide plastic opening tool to pry off the top casing.
    • Be cautious not to crack the casing near the keyboard as it is quite fragile.
    • Lift the cover off carefully as there are wires still attached to internal components.
    • After panel is removed, use an anti-static wrist strap to ensure the motherboard does not get any external shocks from static discharge.
  3. HP 15-r137wm TouchSmart Audio Speakers Replacement: 手順 3、 1の画像 1
    • The connection for the track pad is still connected.
    • Move the keyboard slightly out of the way to locate the connection.
    • Disconnect the small wire protruding from the motherboard underneath the metal plate.
  4. HP 15-r137wm TouchSmart Audio Speakers Replacement: 手順 4、 2の画像 1 HP 15-r137wm TouchSmart Audio Speakers Replacement: 手順 4、 2の画像 2
    • Locate the connection between the power button and the connecting cable.
    • Do not lift the front panel off to far as the cable is still attached.
    • Remove the cable from the motherboard carefully.
  5. HP 15-r137wm TouchSmart Audio Speakers Replacement, Keyboard: 手順 5、 2の画像 1 HP 15-r137wm TouchSmart Audio Speakers Replacement, Keyboard: 手順 5、 2の画像 2
    • Disconnect the connection between the keyboard the the motherboard.
  6. HP 15-r137wm TouchSmart Audio Speakers Replacement: 手順 6、 2の画像 1 HP 15-r137wm TouchSmart Audio Speakers Replacement: 手順 6、 2の画像 2
    • Remove the four (4) 2.5mm by 3.5mm Phillips #0 screws from the metal retaining plate.
    • Lift the metal retaining plate off and away from the device.
  7. HP 15-r137wm TouchSmart Audio Speakers Replacement, Audio Speakers: 手順 7、 2の画像 1 HP 15-r137wm TouchSmart Audio Speakers Replacement, Audio Speakers: 手順 7、 2の画像 2
    • Remove the four (4) 2.5 mm Phillips #0 screws.
  8. HP 15-r137wm TouchSmart Audio Speakers Replacement: 手順 8、 2の画像 1 HP 15-r137wm TouchSmart Audio Speakers Replacement: 手順 8、 2の画像 2
    • Disconnect the power source from the motherboard.
    • The wires are very small and thin, so be careful when removing.
    • Lift the speakers away from the housing by sliding them out from under the motherboard.
終わりに
作成者
1人の作成者と共同作成されました。
Ross B Jacques
メンバー登録日: 10/18/17
857 ポイント
7のガイドは作成済み
チーム
UMass Dartmouth, Team S4-G4, Julie Fall 2017 UMass Dartmouth, Team S4-G4, Julie Fall 2017人のメンバー
UMASSD-JULIE-F17S4G4
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 259
