はじめに
This is a guide on how to replace the cooling fan component in your HP 15-g029wm. This is necessary if you're HP 15-g029wm is overheating. There are 4 steps in this guide that describe how to open the HP 15-g029wm to access the components. Only follow up to step 13 if you only need to clear the fan of debris. Be careful not to damage any of the internal components.
必要な工具と部品
Flip the device face up and open the lid.
Insert an opening pick under the keyboard and pry around the perimeter of the keyboard until it fully releases.
Lift the keyboard slightly.
Use your fingers or an opening pick to unlock the ZIF locking flap that secures the keyboard ribbon cable.
Disconnect the keyboard ribbon cable.
Lift the keyboard off.
