メインコンテンツにスキップ
HP 15-f033wm Screen Replacement
必要な工具と部品
  1. HP 15-f033wm Screen Replacement, Battery: 手順 1、 1の画像 1
    • Turn power off using the power button located in the top left corner of the keyboard. Press and hold the power button for 3 seconds until it turns off.
  2. HP 15-f033wm Screen Replacement: 手順 2、 2の画像 1 HP 15-f033wm Screen Replacement: 手順 2、 2の画像 2
    • Close the laptop and flip it over so that the HP cover logo is on the underside of the laptop.
  3. HP 15-f033wm Screen Replacement: 手順 3、 2の画像 1 HP 15-f033wm Screen Replacement: 手順 3、 2の画像 2
    • Locate the battery and the two switches that release the battery when they are unlocked.
  4. HP 15-f033wm Screen Replacement: 手順 4、 2の画像 1 HP 15-f033wm Screen Replacement: 手順 4、 2の画像 2
    • Slide the left switch to the right so that the icon of a locked padlock is no longer visible and the icon of an unlocked padlock is now visible.
  5. HP 15-f033wm Screen Replacement: 手順 5、 3の画像 1 HP 15-f033wm Screen Replacement: 手順 5、 3の画像 2 HP 15-f033wm Screen Replacement: 手順 5、 3の画像 3
    • With your left hand, slide the right switch to the left and hold it in place. This will unlock the battery and allow you to easily slide it out of its port.
    • While holding the switch in place, use your right hand to gently remove the battery from its port.
  6. HP 15-f033wm Screen Replacement, Screen: 手順 6、 1の画像 1
    • After removing the battery, remove the bezel. Do this by prying it away from the faulty screen using the spudger.
    • Make sure screen is angles as far back as possible to fully remove the bottom hinges of the bezel without damaging the laptop.
  7. HP 15-f033wm Screen Replacement: 手順 7、 1の画像 1
    • Remove the four 3 mm PH1 Phillips head screws in each corner of the screen, fastening the screen to the rest of the laptop.
  8. HP 15-f033wm Screen Replacement: 手順 8、 1の画像 1
    • Gently remove the screen and place it on the keyboard.
  9. HP 15-f033wm Screen Replacement: 手順 9、 2の画像 1 HP 15-f033wm Screen Replacement: 手順 9、 2の画像 2
    • Remove the tape on top of the video cable.
    • Gently disconnect the video cable.
終わりに
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Aaron Chabot
メンバー登録日: 10/17/17
620 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G4, Simcock Fall 2017 UMass Dartmouth, Team S1-G4, Simcock Fall 2017人のメンバー
UMASSD-SIMCOCK-F17S1G4
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 1,502
