メインコンテンツにスキップ
HP 15-ef2025nr Fan Replacement
必要な工具と部品
  1. HP 15-ef2025nr Fan Replacement, Battery: 手順 1、 1の画像 1
    • Turn the laptop upside down with the hinge facing you.
  2. HP 15-ef2025nr Fan Replacement: 手順 2、 2の画像 1 HP 15-ef2025nr Fan Replacement: 手順 2、 2の画像 2
    • Use an opening tool to remove the rubber strips by prying up a corner and gently pulling off the strip.
  3. HP 15-ef2025nr Fan Replacement: 手順 3、 2の画像 1 HP 15-ef2025nr Fan Replacement: 手順 3、 2の画像 2
    • Use a Phillips screwdriver to remove the eight 3 mm screws (including the 2 screws that were not under the rubber strips) securing the lower case.
  4. HP 15-ef2025nr Fan Replacement: 手順 4、 2の画像 1 HP 15-ef2025nr Fan Replacement: 手順 4、 2の画像 2
    • Flip the laptop over and open the lid.
    • Insert an opening tool into the seam between the edge of the lower case and the chassis.
    • Gently pry around the entire perimeter until the lower case separates from the chassis.
    • Close the lid and flip the laptop back over.
    • Remove the lower case.
  5. HP 15-ef2025nr Fan Replacement: 手順 5、 3の画像 1 HP 15-ef2025nr Fan Replacement: 手順 5、 3の画像 2 HP 15-ef2025nr Fan Replacement: 手順 5、 3の画像 3
    • Remove the five 2 mm Phillips screws holding the battery down.
    • Take care not to puncture, bend, or twist the battery. Lithium batteries can be very volatile. Follow all proper hazardous disposal laws where you live.
    • Gently lift the front edge of the battery up to disconnect the socket.
    • Lift the battery up and out.
  6. HP 15-ef2025nr Fan Replacement, Fan: 手順 6、 3の画像 1 HP 15-ef2025nr Fan Replacement, Fan: 手順 6、 3の画像 2 HP 15-ef2025nr Fan Replacement, Fan: 手順 6、 3の画像 3
    この手順で使用する道具:
    購入する
    • Use tweezers to pull the fan connector directly out of its motherboard socket.
    • Do not pull on the wires; they are very delicate.
  7. HP 15-ef2025nr Fan Replacement: 手順 7、 3の画像 1 HP 15-ef2025nr Fan Replacement: 手順 7、 3の画像 2 HP 15-ef2025nr Fan Replacement: 手順 7、 3の画像 3
    • Remove the three 2 mm Phillips screws at the top corners and four o'clock position on the fan.
    • Remove the fan.
終わりに
作成者
4人の作成者と共同で作成されました。
kyle mccomas
メンバー登録日: 02/13/23
291 ポイント
2のガイドは作成済み
チーム
Austin Community College, Team 1-1, Watkins Spring 2023 Austin Community College, Team 1-1, Watkins Spring 2023人のメンバー
AUSTINCC-WATKINS-S23S1G1
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 11
過去 30 日: 19
今までの合計 182
