メインコンテンツにスキップ
HP 15-ef Rubber Feet Replacement
必要な工具と部品
  1. HP 15-ef Rubber Feet Replacement, Flip your laptop over: 手順 1、 1の画像 1
    • Flip your laptop over so the rubber feet are facing up.
  2. HP 15-ef Rubber Feet Replacement, Peel up an end of the front foot: 手順 2、 3の画像 1 HP 15-ef Rubber Feet Replacement, Peel up an end of the front foot: 手順 2、 3の画像 2 HP 15-ef Rubber Feet Replacement, Peel up an end of the front foot: 手順 2、 3の画像 3
    • The rubber feet cover a total of six back cover screws.
    • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
    • Make sure both the foot and its adhesive peel up together, as they need to be removed as one piece.
  3. HP 15-ef Rubber Feet Replacement, Remove the front foot: 手順 3、 3の画像 1 HP 15-ef Rubber Feet Replacement, Remove the front foot: 手順 3、 3の画像 2 HP 15-ef Rubber Feet Replacement, Remove the front foot: 手順 3、 3の画像 3
    • Peel the front foot away from the back cover and remove it.
  4. HP 15-ef Rubber Feet Replacement, Remove the rear foot: 手順 4、 3の画像 1 HP 15-ef Rubber Feet Replacement, Remove the rear foot: 手順 4、 3の画像 2 HP 15-ef Rubber Feet Replacement, Remove the rear foot: 手順 4、 3の画像 3
    • Use an opening pick to peel up an end of the rear rubber foot until you can grip it with your fingers.
    • Peel the rear foot away from the back cover and remove it.
  5. HP 15-ef Rubber Feet Replacement, Reassembly information: 手順 5、 3の画像 1 HP 15-ef Rubber Feet Replacement, Reassembly information: 手順 5、 3の画像 2 HP 15-ef Rubber Feet Replacement, Reassembly information: 手順 5、 3の画像 3
    この手順で使用する道具:
    Tesa 61395 Tape
    $5.99
    購入する
    • Note that the rubber feet are different:
    • The rear foot is thicker, with a deeper recess.
    • The front foot is thinner, with a shallower recess.
    • During reassembly:
    • If you're reusing the rubber feet, the leftover adhesive should be tacky enough to reuse.
    • If the leftover adhesive isn't sticky enough or your replacement feet didn't come with adhesive, you can use double-sided tape such as Tesa Tape to secure the feet.
    • Make sure the strips of tape aren't wider than 6 mm, otherwise they may not fit.
    • To install a foot, remove its adhesive liner, lay the foot into its matching recess, and press down firmly along the entire length of the foot to secure it.
終わりに
作成者
1人の作成者と共同作成されました。
Spencer Day
メンバー登録日: 09/14/22
55,203 ポイント
408のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,432のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 79
今までの合計 754
