メインコンテンツにスキップ
HP 15-dy2024nr Trackpad Replacement
必要な工具と部品
  1. HP 15-dy2024nr Trackpad Replacement, Back Cover: 手順 1、 2の画像 1 HP 15-dy2024nr Trackpad Replacement, Back Cover: 手順 1、 2の画像 2
    • Use a spudger to peel one corner of each of the rubber feet from the bottom of the laptop.
    • Gently peel the feet from the laptop using the spudger revealing the screws underneath.
    • If the rubber foot peels away but leaves adhesive behind you must peel the adhesive away before removing the screws.
  2. HP 15-dy2024nr Trackpad Replacement: 手順 2、 3の画像 1 HP 15-dy2024nr Trackpad Replacement: 手順 2、 3の画像 2 HP 15-dy2024nr Trackpad Replacement: 手順 2、 3の画像 3
    • Use a Phillips #1 screwdriver to remove:
    • Two 2.5mm x 6mm screws
    • Six 2mm x 6mm screws
    • Be sure to keep different screw sizes separated.
  3. HP 15-dy2024nr Trackpad Replacement: 手順 3、 3の画像 1 HP 15-dy2024nr Trackpad Replacement: 手順 3、 3の画像 2 HP 15-dy2024nr Trackpad Replacement: 手順 3、 3の画像 3
    • Insert an iFixit opening tool into the seam between the keyboard area and bottom cover.
    • Using another iFixit opening tool, slide along the seam to unhook the clips.
    • There are clips all the way around the seam. You may hear a popping sound as the clips come loose. This step may require some force to separate the back cover from the laptop.
    • When the front of the laptop is open, you can use your finger to hold a corner open then slide an iFixit opening tool along the seam toward the back corner.
    • After the clips have been released, flip the laptop over and lift the cover.
  4. HP 15-dy2024nr Trackpad Replacement, Battery: 手順 4、 3の画像 1 HP 15-dy2024nr Trackpad Replacement, Battery: 手順 4、 3の画像 2 HP 15-dy2024nr Trackpad Replacement, Battery: 手順 4、 3の画像 3
    • Remove five 2.0mm x 3.0mm screws using a Phillips #00 screwdriver.
    • Use the iFixit opening picks to lift the battery away from the laptop.
  5. HP 15-dy2024nr Trackpad Replacement: 手順 5、 3の画像 1 HP 15-dy2024nr Trackpad Replacement: 手順 5、 3の画像 2 HP 15-dy2024nr Trackpad Replacement: 手順 5、 3の画像 3
    • Be aware that the battery is plugged into the motherboard.
    • Unplug the battery from the motherboard.
    • Lift the battery away from the laptop and remove.
  6. HP 15-dy2024nr Trackpad Replacement, Trackpad: 手順 6、 2の画像 1 HP 15-dy2024nr Trackpad Replacement, Trackpad: 手順 6、 2の画像 2
    • Remove two 3.0 mm screws using a Phillips #1 screwdriver.
    • Lift the metal bracket away from the laptop and remove it with your hands.
  7. HP 15-dy2024nr Trackpad Replacement: 手順 7、 1の画像 1
    • Remove three 2.0 mm screws using a Phillips #0 screwdriver.
  8. HP 15-dy2024nr Trackpad Replacement: 手順 8、 1の画像 1
    • Lift the track pad away from the laptop and remove with your hands.
終わりに
作成者
1人の作成者と共同作成されました。
Eylandra
メンバー登録日: 02/08/24
97 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 5-5, Coppersmith Spring 2024 University of North Texas, Team 5-5, Coppersmith Spring 2024人のメンバー
UNT-COPPERSMITH-S24S5G5
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 56
