メインコンテンツにスキップ
HP 15-da0002dx Fan Replacement
必要な工具と部品
  1. HP 15-da0002dx Fan Replacement, Back Cover: 手順 1、 1の画像 1
    • Make sure the computer is completely turned off.
  2. HP 15-da0002dx Fan Replacement: 手順 2、 1の画像 1
    • Turn over the laptop.
    • The HP label should be touching the table and the bottom cover should be facing up.
  3. HP 15-da0002dx Fan Replacement: 手順 3、 2の画像 1 HP 15-da0002dx Fan Replacement: 手順 3、 2の画像 2
    • Two plastic feet are located on adjacent sides of the back cover.
    • Peel back the plastic feet using the plastic opening tools.
  4. HP 15-da0002dx Fan Replacement: 手順 4、 1の画像 1
    • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
  5. HP 15-da0002dx Fan Replacement: 手順 5、 1の画像 1
    • Carefully flip over the computer so the HP label is now facing the ceiling.
  6. HP 15-da0002dx Fan Replacement: 手順 6、 2の画像 1 HP 15-da0002dx Fan Replacement: 手順 6、 2の画像 2
    • Open the screen.
    • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
  7. HP 15-da0002dx Fan Replacement: 手順 7、 1の画像 1
    • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
  8. HP 15-da0002dx Fan Replacement, Battery: 手順 8、 1の画像 1
    • Remove the screws holding the battery in place using a Phillips #1 screwdriver.
  9. HP 15-da0002dx Fan Replacement: 手順 9、 2の画像 1 HP 15-da0002dx Fan Replacement: 手順 9、 2の画像 2
    • Using your fingers, tilt the top part of the battery towards you.
    • Continue to pull the rest of the battery away from the mounting tabs to remove.
  10. HP 15-da0002dx Fan Replacement, Fan: 手順 10、 2の画像 1 HP 15-da0002dx Fan Replacement, Fan: 手順 10、 2の画像 2
    • Hold the fan in place and remove the one 8.0 mm screw from the fan .
  11. HP 15-da0002dx Fan Replacement: 手順 11、 1の画像 1
    • Pull out the connector for the fan cable using the opening tool or spudger.
  12. HP 15-da0002dx Fan Replacement: 手順 12、 1の画像 1
    • Carefully take out the fan from the computer.
終わりに
作成者
1人の作成者と共同作成されました。
Abigail Aron
メンバー登録日: 09/04/19
941 ポイント
5のガイドは作成済み
チーム
University of Alabama, Team S2-G8, Bedsole Fall 2019 University of Alabama, Team S2-G8, Bedsole Fall 2019人のメンバー
UA-BEDSOLE-F19S2G8
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 34
今までの合計 1,323
