メインコンテンツにスキップ
HP 15-d076nr Wireless Card Replacement
必要な工具と部品
  1. HP 15-d076nr Wireless Card Replacement, Battery: 手順 1、 1の画像 1
    • Orient the laptop upside down so that the back of the laptop, where the battery is located, faces you.
    • Locate the left and right switches at the bottom of the laptop.
  2. HP 15-d076nr Wireless Card Replacement: 手順 2、 1の画像 1
    • Move the right switch to the left so that the orange unlock symbol is showing.
  3. HP 15-d076nr Wireless Card Replacement: 手順 3、 1の画像 1
    • Move the left switch to the right, covering the battery symbol, and hold.
  4. HP 15-d076nr Wireless Card Replacement: 手順 4、 1の画像 1
    • While holding the left switch in place, slide the battery towards you and away from the laptop.
  5. HP 15-d076nr Wireless Card Replacement, Wireless Card: 手順 5、 1の画像 1
    • Re-orient the laptop, so that the back of the laptop faces away from you.
  6. HP 15-d076nr Wireless Card Replacement: 手順 6、 1の画像 1
    • Locate the small screw on the panel at the center of the laptop.
    • Loosen the small screw using a Philips # 1 screwdriver.
    • The screw does not come free from the panel. It only needs to be loosened enough so that the panel can be lifted/pried.
  7. HP 15-d076nr Wireless Card Replacement: 手順 7、 2の画像 1 HP 15-d076nr Wireless Card Replacement: 手順 7、 2の画像 2
    • Carefully pry the middle panel up using a plastic spudger, or other prying tool .
    • Pull the panel away from the laptop and set it off to the side.
  8. HP 15-d076nr Wireless Card Replacement: 手順 8、 2の画像 1 HP 15-d076nr Wireless Card Replacement: 手順 8、 2の画像 2
    • Gently wiggle and lift the black antenna wire away from the wireless card.
    • If there is also a white wire attached, both black and white wires will need to be removed from the wireless card.
  9. HP 15-d076nr Wireless Card Replacement: 手順 9、 3の画像 1 HP 15-d076nr Wireless Card Replacement: 手順 9、 3の画像 2 HP 15-d076nr Wireless Card Replacement: 手順 9、 3の画像 3
    • Locate the Phillips 2.0x3.0mm screw on the upper left corner of the wireless card.
    • Carefully remove the 2.0x3.0mm screw using a Philips #0 screwdriver.
  10. HP 15-d076nr Wireless Card Replacement: 手順 10、 1の画像 1
    • Slide the wireless card to the left to remove it from the socket.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Gabrielle Farren
メンバー登録日: 01/12/17
161 ポイント
1ガイドが承認済み
チーム
Oakland University, Team 2-2, Ruskiewicz Winter 2017 Oakland University, Team 2-2, Ruskiewicz Winter 2017人のメンバー
OAK-RUSKIEWICZ-W17S2G2
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 3
今までの合計 550
