メインコンテンツにスキップ
HP 15-ba0709dx Hard Drive Replacement
必要な工具と部品
  1. HP 15-ba0709dx Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch on the left and right side until the battery is detached from its slot.
    • A noticeable pop will be heard when the battery is fully released.
  2. HP 15-ba0709dx Hard Drive Replacement: 手順 2、 1の画像 1
    • Pull the battery out of its slot.
    • Be careful not to damage any of the connectors in the process.
  3. HP 15-ba0709dx Hard Drive Replacement, Back Cover: 手順 3、 1の画像 1
    • Place the laptop on a clean, flat surface with the bottom side facing up.
  4. HP 15-ba0709dx Hard Drive Replacement: 手順 4、 1の画像 1
    • Using a Phillips Head Screwdriver, remove the screws anchoring the bottom casing.
    • Note: Make sure to keep track of the screws once they have been removed.
  5. HP 15-ba0709dx Hard Drive Replacement: 手順 5、 1の画像 1
    • Locate the screws about 1 inch from the battery release tabs and use a Phillips Head Screwdriver to remove these screws.
    • Note:Place these newly removed screws with the ones removed in Step 2.
  6. HP 15-ba0709dx Hard Drive Replacement: 手順 6、 2の画像 1 HP 15-ba0709dx Hard Drive Replacement: 手順 6、 2の画像 2
    • Locate the rubber friction pads on the top corners of the laptop. Pry the pads from the laptop and place them off to the side
    • Removing the friction pads will reveal two more anchoring screws.
    • Note: The adhesive keeping the pads on the laptop will weaken once doing this, but it is necessary to removing the bottom cover of the laptop.
  7. HP 15-ba0709dx Hard Drive Replacement: 手順 7、 1の画像 1
    • Remove disc reader.
    • Note: If all screws are removed it should slide out easily.
  8. HP 15-ba0709dx Hard Drive Replacement: 手順 8、 2の画像 1 HP 15-ba0709dx Hard Drive Replacement: 手順 8、 2の画像 2
    • Use a plastic prod to pry the back cover off the laptop.
    • Be careful not to damage the laptop while prying.
  9. HP 15-ba0709dx Hard Drive Replacement, Hard Drive: 手順 9、 1の画像 1
    • Locate the square, blue hard drive
    • Unscrew the two screws holding it in place using a Philips screwdriver head, PH1. The screws will be 8 mm long with a 4 mm width head.
  10. HP 15-ba0709dx Hard Drive Replacement: 手順 10、 1の画像 1
    • Lift the hard drive out of its slot after screws are removed.
  11. HP 15-ba0709dx Hard Drive Replacement: 手順 11、 1の画像 1
    • Squeeze to release and pull adapter cable from the side of hard drive.
    • Be careful not to damage the adapter.
終わりに
5 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Lydia Brown
メンバー登録日: 03/20/17
369 ポイント
2のガイドは作成済み
チーム
Texas Tech, Team S13-G3, Bennett Spring 2017 Texas Tech, Team S13-G3, Bennett Spring 2017人のメンバー
TTU-BENNETT-S17S13G3
5 メンバー
5のガイドは作成済み
コメント 1 件
Many thanks for this! The adhesive pads were foiling my attempts, and I was afraid of breaking things. Perfect instructions, I accomplished my goal :)
Diana K - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 15
今までの合計 5,358
