メインコンテンツにスキップ
HP 15-ay103dx Display Screen Hinges Replacement
必要な工具と部品
  1. HP 15-ay103dx Display Screen Hinges Replacement, Battery: 手順 1、 1の画像 1
    • Slide the two battery lock latches on the back of the device to the “unlock” position.
  2. HP 15-ay103dx Display Screen Hinges Replacement: 手順 2、 1の画像 1
    • Lift the battery upward to remove it from the device.
  3. HP 15-ay103dx Display Screen Hinges Replacement, Back Panel: 手順 3、 1の画像 1
    • Using the PH1 phillips-head screwdriver, remove all the 5/16 in. screws from the back of the device.
    • There should be 10 in total, be sure to keep them together!
  4. HP 15-ay103dx Display Screen Hinges Replacement: 手順 4、 1の画像 1
    • Locate the optical disc drive and remove it from the device by sliding it straight of the device.
  5. HP 15-ay103dx Display Screen Hinges Replacement: 手順 5、 2の画像 1 HP 15-ay103dx Display Screen Hinges Replacement: 手順 5、 2の画像 2
    • Covering the hinges of the device are rubber bumpers secured to the device using adhesive. Remove them carefully.
    • Place the adhesive side up as you will need to place them back after your replacement is complete.
  6. HP 15-ay103dx Display Screen Hinges Replacement: 手順 6、 2の画像 1 HP 15-ay103dx Display Screen Hinges Replacement: 手順 6、 2の画像 2
    • In the same spot you’ve just removed the bumpers from, you will find two 5/16 in. screws. Using the same Phillips-head screwdriver used in step 2, remove the screws
    • Be sure to keep the screws together!
  7. HP 15-ay103dx Display Screen Hinges Replacement: 手順 7、 1の画像 1
    • Carefully remove the back panel from the device.
    • If you are unable to do this with your hands, you can use a thin prying tool of your choice to make it easier!
  8. HP 15-ay103dx Display Screen Hinges Replacement, Display Screen Hinges: 手順 8、 2の画像 1 HP 15-ay103dx Display Screen Hinges Replacement, Display Screen Hinges: 手順 8、 2の画像 2
    • Use a spudger to carefully remove the border around the display screen.
    • As long as you are slow and delicate, the border will eventually come off.
  9. HP 15-ay103dx Display Screen Hinges Replacement: 手順 9、 2の画像 1 HP 15-ay103dx Display Screen Hinges Replacement: 手順 9、 2の画像 2
    • Remove the two 5/16 screws in the top corners and the four in the bottom corners.
  10. HP 15-ay103dx Display Screen Hinges Replacement: 手順 10、 1の画像 1
    • Carefully pull the screen from the hinges and lower it on to the table.
    • There will be wires running from the screen to the motherboard. You do not need to unplug these.
    • The hinges are made of malleable metal and are easily bent.
  11. HP 15-ay103dx Display Screen Hinges Replacement: 手順 11、 1の画像 1
    • Remove the 5/16 screws securing the hinges to the computer.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Kody Franklin
メンバー登録日: 09/25/17
131 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S3-G3, Thompson Fall 2017 University of North Texas, Team S3-G3, Thompson Fall 2017人のメンバー
UNT-THOMPSON-F17S3G3
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 757
