メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP 15-ay052nr USB Port Replacement
必要な工具と部品
  1. HP 15-ay052nr USB Port Replacement, Battery: 手順 1、 1の画像 1
    • To protect the device and yourself, make sure your device is completely powered down before disassembling. Disconnect all external devices before starting any tear down process.
    • Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
    FixBotに聞いてみる
  2. HP 15-ay052nr USB Port Replacement: 手順 2、 1の画像 1
    • Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
    • The sliders are located at the back of the device on the side where the display hinges are.
    • The slider closest to the optical drive (CD reader) clicks open but the opposite slider has a spring.
    FixBotに聞いてみる
  3. HP 15-ay052nr USB Port Replacement: 手順 3、 1の画像 1
    • Pull the battery slightly up and out to remove.
    • If the battery doesn't pop out, the sliders weren't pushed in far enough. Push the sliders towards the center until the battery pops out.
    FixBotに聞いてみる
  4. HP 15-ay052nr USB Port Replacement, Bottom Cover: 手順 4、 1の画像 1
    • Remove the rubber feet on the bottom of the device to access all the screws.
    • There are two rubber feet, one on each side of the battery compartment.
    FixBotに聞いてみる
  5. HP 15-ay052nr USB Port Replacement: 手順 5、 1の画像 1
    • Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
    • Gently remove the optical drive (CD reader) to more easily separate the base.
    FixBotに聞いてみる
  6. HP 15-ay052nr USB Port Replacement: 手順 6、 1の画像 1
    • Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
    FixBotに聞いてみる
  7. HP 15-ay052nr USB Port Replacement: 手順 7、 1の画像 1
    • Separate the base of the computer from the component assembly.
    • The optical drive can be placed in the base where it corresponds to prevent misplacing it.
    FixBotに聞いてみる
  8. HP 15-ay052nr USB Port Replacement, USB Port: 手順 8、 1の画像 1
    • Remove the three 3mm JIS #0 screws from the hard drive.
    FixBotに聞いてみる
  9. HP 15-ay052nr USB Port Replacement: 手順 9、 1の画像 1
    • Unplug the hard drive and set aside.
    FixBotに聞いてみる
  10. HP 15-ay052nr USB Port Replacement: 手順 10、 1の画像 1
    • Disconnect the cable that is attached to the motherboard from the USB board.
    • The motherboard can be identified as the big blue board in the opposite side of the USB board we are replacing.
    FixBotに聞いてみる
  11. HP 15-ay052nr USB Port Replacement: 手順 11、 1の画像 1
    • Remove the single 3mm JIS #0 screw.
    • Once the screw is out, the USB board can be pulled out for replacement.
    FixBotに聞いてみる
終わりに
作成者
3人の作成者と共同で作成されました。
Morgan Distler
メンバー登録日: 01/10/19
914 ポイント
5のガイドは作成済み
チーム
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 38
今までの合計 607
