メインコンテンツにスキップ
HP 15-ay014dx Wireless Card Replacement
必要な工具と部品
  1. HP 15-ay014dx Wireless Card Replacement, Battery: 手順 1、 1の画像 1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Wireless Card Replacement: 手順 2、 1の画像 1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Wireless Card Replacement: 手順 3、 1の画像 1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx Wireless Card Replacement, Optical Drive: 手順 4、 1の画像 1
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx Wireless Card Replacement: 手順 5、 1の画像 1
    • Grip the optical drive and gently pull it out.
  6. HP 15-ay014dx Wireless Card Replacement, Wireless Card: 手順 6、 1の画像 1
    • Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  7. HP 15-ay014dx Wireless Card Replacement: 手順 7、 2の画像 1 HP 15-ay014dx Wireless Card Replacement: 手順 7、 2の画像 2
    • Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
  8. HP 15-ay014dx Wireless Card Replacement: 手順 8、 2の画像 1 HP 15-ay014dx Wireless Card Replacement: 手順 8、 2の画像 2
    • Using the spudger, carefully pry the wire connecting the wireless card to the motherboard off of it.
  9. HP 15-ay014dx Wireless Card Replacement: 手順 9、 1の画像 1
    • Using the size #00 Phillips screwdriver remove the single screw holding it in place.
  10. HP 15-ay014dx Wireless Card Replacement: 手順 10、 1の画像 1
    • carefully pull the card of its slot.
終わりに
作成者
2人の作成者と共同で作成されました。
Drake Scoville
メンバー登録日: 09/21/17
533 ポイント
4のガイドは作成済み
チーム
Washington State, Team S1-G4, Phelps-Hillen Fall 2017 Washington State, Team S1-G4, Phelps-Hillen Fall 2017人のメンバー
WSU-PHELPS-HILLEN-F17S1G4
6 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 386
