メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
This guide will show you how to safely remove the RAM in your HP 15-ay014dx laptop for replacement.
パーツ
パーツは指定されていません。
  1. Disconnect device from power source and power down.
    • Disconnect device from power source and power down.
  2. With the device turned upside down, use your index fingers to push the battery latches in towards each other.
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  5. Close the laptop and lay it down with the bottom facing up.
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  6. Grip the optical drive and gently pull it out.
    • Grip the optical drive and gently pull it out.
  7. Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
    • Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  8. Use the spudger to press the tabs in the back of the computer. Carefully remove the back of the laptop by prying around the sides using the plastic opening tool. Use the spudger to press the tabs in the back of the computer. Carefully remove the back of the laptop by prying around the sides using the plastic opening tool.
    • Use the spudger to press the tabs in the back of the computer. Carefully remove the back of the laptop by prying around the sides using the plastic opening tool.
  9. Undo the clips holding the RAM in place using the plastic opening tool. Undo the clips holding the RAM in place using the plastic opening tool.
    • Undo the clips holding the RAM in place using the plastic opening tool.
  10. Carefully pull out the RAM from the motherboard.
    • Carefully pull out the RAM from the motherboard.
終わりに
6 の人々がこのガイドを完成させました。
Drake Scoville
メンバー登録日: 2017年09月21日
512 ポイント
4のガイドは作成済み
チーム
Washington State, Team S1-G4, Phelps-Hillen Fall 2017 Washington State, Team S1-G4, Phelps-Hillen Fall 2017人のメンバー
WSU-PHELPS-HILLEN-F17S1G4
6 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 331
