メインコンテンツにスキップ
HP 15-af013cl Front Facing Camera Replacement
必要な工具と部品
  1. HP 15-af013cl Front Facing Camera Replacement, Battery: 手順 1、 1の画像 1
    • Start off by flipping the laptop on its back.
  2. HP 15-af013cl Front Facing Camera Replacement: 手順 2、 3の画像 1 HP 15-af013cl Front Facing Camera Replacement: 手順 2、 3の画像 2 HP 15-af013cl Front Facing Camera Replacement: 手順 2、 3の画像 3
    • Push the two spring-loaded tabs inward.
    • Once unlatched, pull the battery out of its compartment.
  3. HP 15-af013cl Front Facing Camera Replacement, Screen: 手順 3、 1の画像 1
    • Flip the laptop over and have it open as you normally would.
  4. HP 15-af013cl Front Facing Camera Replacement: 手順 4、 3の画像 1 HP 15-af013cl Front Facing Camera Replacement: 手順 4、 3の画像 2 HP 15-af013cl Front Facing Camera Replacement: 手順 4、 3の画像 3
    • Using a pry tool, unclip the entire outer plastic cover from the front of the screen.
    • Gently remove the front plastic cover.
  5. HP 15-af013cl Front Facing Camera Replacement: 手順 5、 1の画像 1
    • Remove the two 2.5mm × 3.0mm Phillips screws from each corner of the display.
  6. HP 15-af013cl Front Facing Camera Replacement: 手順 6、 2の画像 1 HP 15-af013cl Front Facing Camera Replacement: 手順 6、 2の画像 2
    • Carefully lift the display out of the laptop shell and flip it on its front.
    • Disconnect the single cable from the back of the display.
  7. HP 15-af013cl Front Facing Camera Replacement, Front Facing Camera: 手順 7、 2の画像 1 HP 15-af013cl Front Facing Camera Replacement, Front Facing Camera: 手順 7、 2の画像 2
    • The front camera is held in by light adhesive. Pry gently on the back of the camera in order to remove it.
    • Remove the cable from under the metal foil.
  8. HP 15-af013cl Front Facing Camera Replacement: 手順 8、 1の画像 1
    • Flip the laptop back over.
    • Using the Phillips P0 screwdriver, remove the 9 M2.5mm x 6.5mm screws from the bottom of the laptop.
    • Remove the additional 2 M2.0mm × 1.5mm Phillips screws located in the battery compartment.
  9. HP 15-af013cl Front Facing Camera Replacement: 手順 9、 2の画像 1 HP 15-af013cl Front Facing Camera Replacement: 手順 9、 2の画像 2
    • Remove the optical disk drive from the side of the laptop.
  10. HP 15-af013cl Front Facing Camera Replacement: 手順 10、 1の画像 1
    • Lift off the bottom cover, exposing the motherboard and other components underneath.
  11. HP 15-af013cl Front Facing Camera Replacement: 手順 11、 1の画像 1
    • Disconnect the display ribbon cable from the motherboard.
終わりに
作成者
2人の作成者と共同で作成されました。
Stephen Perreira
メンバー登録日: 09/27/17
787 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team S8-G6, Banghart Fall 2017 Cal Poly, Team S8-G6, Banghart Fall 2017人のメンバー
CPSU-BANGHART-F17S8G6
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 7
今までの合計 384
