メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This guide will teach you how to replace the motherboard, which contains the USB ports. You will need plastic prying tools and a Phillips J001 screw driver.
  1. Remove all external devices from the computer.
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. Turn off the computer by holding the power button.
    • Turn off the computer by holding the power button.
  3. To remove the battery, slide the left slider on the back to the unlocked position. To remove the battery, slide the left slider on the back to the unlocked position.
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. Push the right slider inwards. Remove the battery out by pulling straight out and to the right.
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. Locate the CD Compartment panel and gently slide it out. Locate the CD Compartment panel and gently slide it out. Locate the CD Compartment panel and gently slide it out.
    • Locate the CD Compartment panel and gently slide it out.
  6. 全てのタブを開く
    Mac用RAMアップグレードキット
    キット商品を見る
    どれだけタブを開いても
    十分に足りるRAM容量
    キット商品を見る
  7. Remove the back of the laptop by unscrewing the screws shown.
    • Remove the back of the laptop by unscrewing the screws shown.
    • Also remove the other 5 Phillips screws lining the back cover.
  8. Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off. Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed! Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
  9. Locate the Fan as shown. Pull out the black cable, with four wires attached from its port. Pull out the black cable, with four wires attached from its port.
    • Locate the Fan as shown.
    • Pull out the black cable, with four wires attached from its port.
  10. Pull out the white cable wire from its port. Unscrew the two black Phillips screws holding in the fan.
    • Pull out the white cable wire from its port.
    • Unscrew the two black Phillips screws holding in the fan.
  11. Remove fan. Unscrew the two screws holding in the fan.
    • Remove fan.
    • Unscrew the two screws holding in the fan.
  12. Locate the CD Compartment as shown and gently slide it out. Locate the CD Compartment as shown and gently slide it out. Locate the CD Compartment as shown and gently slide it out.
    • Locate the CD Compartment as shown and gently slide it out.
  13. Remove the TEN 3mm screws.
    • Remove the TEN 3mm screws.
    • Remove the ONE 9mm screw.
  14. Locate the four ribbon clips. Lift the grey part of the ribbon clips.
    • Locate the four ribbon clips.
    • Lift the grey part of the ribbon clips.
    • Pull the ribbon cable out and repeat this step for all four ribbon cables.
    • Also use a spudger and release the TWO cables attaching the hard drive to the motherboard. Another ribbon cable is located where the fan was sitting.
  15. Pull out the white cable (contains red and white cable attached to a black support) with wires from its port. Pull out the white cable (contains red and white cable attached to a black support) with wires from its port.
    • Pull out the white cable (contains red and white cable attached to a black support) with wires from its port.
  16. Remove the motherboard.
    • Remove the motherboard.
終わりに
ある他の人がこのガイドを完成しました。
Onose Aigbe
メンバー登録日: 2018年01月30日
390 ポイント
3のガイドは作成済み
チーム
Baylor, Team S1-G2, Johnson Spring 2018 Baylor, Team S1-G2, Johnson Spring 2018人のメンバー
BU-JOHNSON-S18S1G2
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 22
今までの合計 671
