メインコンテンツにスキップ
HP 15-ac121dx CD Compartment Replacement
必要な工具と部品
  1. HP 15-ac121dx CD Compartment Replacement, Battery: 手順 1、 1の画像 1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx CD Compartment Replacement: 手順 2、 1の画像 1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx CD Compartment Replacement: 手順 3、 2の画像 1 HP 15-ac121dx CD Compartment Replacement: 手順 3、 2の画像 2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx CD Compartment Replacement: 手順 4、 2の画像 1 HP 15-ac121dx CD Compartment Replacement: 手順 4、 2の画像 2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx CD Compartment Replacement, Back Panel: 手順 5、 3の画像 1 HP 15-ac121dx CD Compartment Replacement, Back Panel: 手順 5、 3の画像 2 HP 15-ac121dx CD Compartment Replacement, Back Panel: 手順 5、 3の画像 3
    • Locate the CD Compartment panel and gently slide it out.
  6. HP 15-ac121dx CD Compartment Replacement: 手順 6、 1の画像 1
    • Remove the back of the laptop by unscrewing the screws shown.
    • Also remove the other 5 Phillips screws lining the back cover.
  7. HP 15-ac121dx CD Compartment Replacement: 手順 7、 3の画像 1 HP 15-ac121dx CD Compartment Replacement: 手順 7、 3の画像 2 HP 15-ac121dx CD Compartment Replacement: 手順 7、 3の画像 3
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
  8. HP 15-ac121dx CD Compartment Replacement, CD Compartment: 手順 8、 3の画像 1 HP 15-ac121dx CD Compartment Replacement, CD Compartment: 手順 8、 3の画像 2 HP 15-ac121dx CD Compartment Replacement, CD Compartment: 手順 8、 3の画像 3
    • Locate the CD Compartment as shown and gently slide it out.
終わりに
Replace CD compartment. To reassemble your device, follow these instructions in reverse order.
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Ashton Martin
メンバー登録日: 01/30/18
459 ポイント
2のガイドは作成済み
チーム
Baylor, Team S1-G2, Johnson Spring 2018 Baylor, Team S1-G2, Johnson Spring 2018人のメンバー
BU-JOHNSON-S18S1G2
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 9
今までの合計 414
