メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP 15-R011DX Hard Drive Replacement
必要な工具と部品
  1. HP 15-R011DX Hard Drive Replacement, Battery: 手順 1、 2の画像 1 HP 15-R011DX Hard Drive Replacement, Battery: 手順 1、 2の画像 2
    • Slide the lock mechanism on the left side of the laptop to the right.
  2. HP 15-R011DX Hard Drive Replacement: 手順 2、 1の画像 1
    • While holding the right slide mechanism, remove the battery from the laptop.
    • The battery is not pictured here because it is missing from this particular device.
  3. HP 15-R011DX Hard Drive Replacement, How to Access the Internal Components of an HP 15-R011DX: 手順 3、 2の画像 1 HP 15-R011DX Hard Drive Replacement, How to Access the Internal Components of an HP 15-R011DX: 手順 3、 2の画像 2
    • Flip the laptop over to reveal screw locations.
    • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
  4. HP 15-R011DX Hard Drive Replacement: 手順 4、 2の画像 1 HP 15-R011DX Hard Drive Replacement: 手順 4、 2の画像 2
    • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
  5. HP 15-R011DX Hard Drive Replacement: 手順 5、 2の画像 1 HP 15-R011DX Hard Drive Replacement: 手順 5、 2の画像 2
    • Remove the DVD drive from the laptop.
    • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
  6. HP 15-R011DX Hard Drive Replacement: 手順 6、 3の画像 1 HP 15-R011DX Hard Drive Replacement: 手順 6、 3の画像 2 HP 15-R011DX Hard Drive Replacement: 手順 6、 3の画像 3
    • Flip the laptop and open.
    • Detach the keyboard by prying it free from the laptop using a spudger.
    • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
    • Disconnect the keyboard ribbon cable.
  7. HP 15-R011DX Hard Drive Replacement: 手順 7、 2の画像 1 HP 15-R011DX Hard Drive Replacement: 手順 7、 2の画像 2
    • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
    • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
    • Pry open the plastic casing using a spudger.
    • If struggling to remove the plastic case, check that all screws have been removed.
  8. HP 15-R011DX Hard Drive Replacement, Hard Drive: 手順 8、 1の画像 1
    • Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
  9. HP 15-R011DX Hard Drive Replacement: 手順 9、 2の画像 1 HP 15-R011DX Hard Drive Replacement: 手順 9、 2の画像 2
    • Pull the hard drive upwards and away from the laptop.
    • The hard drive should disconnect from its port on the motherboard as shown in the second image.
  10. HP 15-R011DX Hard Drive Replacement: 手順 10、 1の画像 1
    • Flip the hard drive over.
    • Remove the two 4 mm Phillips #1 screws from the base of the hard drive.
    • Remove the mounting brace (silver bracket) from the hard drive.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Ethan Guillotte
メンバー登録日: 03/20/19
517 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G4, Bailey Spring 2019 UMass Dartmouth, Team S2-G4, Bailey Spring 2019人のメンバー
UMASSD-BAILEY-S19S2G4
3 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 38
今までの合計 1,763
