はじめに
This guide will walk you through the step by step process of removing and reinstalling the disc drive in your HP-BA078DX
必要な工具と部品
Unclip the two latches on the bottom of the laptop.
Slide the battery straight out while holding the clip open.
Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
ある他の人がこのガイドを完成しました。
