メインコンテンツにスキップ
HP 15-AF131DX Trackpad Button Circuit Board Replacement
必要な工具と部品
  1. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Battery: 手順 1、 2の画像 1 HP 15-AF131DX Trackpad Button Circuit Board Replacement, Battery: 手順 1、 2の画像 2
    • Turn the computer upside down on a level surface.
    • Slide the battery lock to unlock the battery.
    • Slide the battery release latch. The latch will click when the battery is released.
    • Lift the battery from the middle to remove it from the computer.
    • The latch will click again when a battery is reinstalled. Switch the battery lock back to locked after reinstalling a battery to keep it secure.
  2. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Optical Drive: 手順 2、 2の画像 1 HP 15-AF131DX Trackpad Button Circuit Board Replacement, Optical Drive: 手順 2、 2の画像 2
    • Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
    • Pull the CD/DVD drive outward to slide it away from the computer.
  3. HP 15-AF131DX Trackpad Button Circuit Board Replacement: 手順 3、 1の画像 1
    • To open the drive use an unbent paperclip and press it into the small hole until the disc tray releases.
    • Pull the disc tray out from the front until it is as far as it will go out of the optical drive.
  4. HP 15-AF131DX Trackpad Button Circuit Board Replacement: 手順 4、 3の画像 1 HP 15-AF131DX Trackpad Button Circuit Board Replacement: 手順 4、 3の画像 2 HP 15-AF131DX Trackpad Button Circuit Board Replacement: 手順 4、 3の画像 3
    • To remove excess parts from the optical drive press down on the plastic tab behind the tray's bezel.
    • Gently pry the bezel from the face of the optical drive.
    • With a smaller phillips head screwdriver, remove the screws on the back of the drive, then remove the small metal bracket.
  5. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Trackpad Button Circuit Board: 手順 5、 2の画像 1 HP 15-AF131DX Trackpad Button Circuit Board Replacement, Trackpad Button Circuit Board: 手順 5、 2の画像 2
    • Remove two rubber feet by peeling them off.
    • Remove twelve Phillips head 8.8mm screws using the Phillips #0 Screwdriver.
  6. HP 15-AF131DX Trackpad Button Circuit Board Replacement: 手順 6、 3の画像 1 HP 15-AF131DX Trackpad Button Circuit Board Replacement: 手順 6、 3の画像 2 HP 15-AF131DX Trackpad Button Circuit Board Replacement: 手順 6、 3の画像 3
    • Remove the bottom of the plastic case using a blue plastic opening tool.
    • The Trackpad Button Circuit Board is found in the red box.
  7. HP 15-AF131DX Trackpad Button Circuit Board Replacement: 手順 7、 2の画像 1 HP 15-AF131DX Trackpad Button Circuit Board Replacement: 手順 7、 2の画像 2
    • Remove the two 3.3mm Phillips-head screws that secure the trackpad circuit board to the top cover.
  8. HP 15-AF131DX Trackpad Button Circuit Board Replacement: 手順 8、 2の画像 1 HP 15-AF131DX Trackpad Button Circuit Board Replacement: 手順 8、 2の画像 2
    • Lift the plastic wire lock bracket.
    • Pull on the blue tab to remove the wire using the tweezers tool to make sure there is no damage as you pull.
  9. HP 15-AF131DX Trackpad Button Circuit Board Replacement: 手順 9、 2の画像 1 HP 15-AF131DX Trackpad Button Circuit Board Replacement: 手順 9、 2の画像 2
    • Lift the second plastic wire lock bracket.
    • Pull on the purple tab using tweezers to remove the wire.
  10. HP 15-AF131DX Trackpad Button Circuit Board Replacement: 手順 10、 1の画像 1
    • Lift and remove the trackpad button circuit board.
終わりに
作成者
2人の作成者と共同で作成されました。
Adrianna
メンバー登録日: 11/01/18
133 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S2-G2, Harley Fall 2018 IUPUI, Team S2-G2, Harley Fall 2018人のメンバー
IUPUI-HARLEY-F18S2G2
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 337
