メインコンテンツにスキップ
HP 14-r008la Hard Disk Replacement
必要な工具と部品
  1. HP 14-r008la Hard Disk Replacement, Hard Disk: 手順 1、 3の画像 1 HP 14-r008la Hard Disk Replacement, Hard Disk: 手順 1、 3の画像 2 HP 14-r008la Hard Disk Replacement, Hard Disk: 手順 1、 3の画像 3
    • Shutdown the computer and remove the battery
    • Turn it right-side down, print a picture of its back cover
  2. HP 14-r008la Hard Disk Replacement, Removing screws: 手順 2、 3の画像 1 HP 14-r008la Hard Disk Replacement, Removing screws: 手順 2、 3の画像 2 HP 14-r008la Hard Disk Replacement, Removing screws: 手順 2、 3の画像 3
    • Use double-sided tape to stick all the screws in its right place on the printed picture
    • Under the ram cover there is a screw, remove it
    • Dvd reader will come off when you remove its screw
    • Remove the two screws under the DVD reader
  3. HP 14-r008la Hard Disk Replacement, Removing rubber feet and Keyboard: 手順 3、 3の画像 1 HP 14-r008la Hard Disk Replacement, Removing rubber feet and Keyboard: 手順 3、 3の画像 2 HP 14-r008la Hard Disk Replacement, Removing rubber feet and Keyboard: 手順 3、 3の画像 3
    • Remove the two rubber feet beside battery place
    • Turn the laptop right-side up and open and insert a pry tool along the top-side keyboard until release it
    • Release the connector to which the keyboard cable is attached, and then disconnect the keyboard cable.
  4. HP 14-r008la Hard Disk Replacement, Remove mother board cover: 手順 4、 3の画像 1 HP 14-r008la Hard Disk Replacement, Remove mother board cover: 手順 4、 3の画像 2 HP 14-r008la Hard Disk Replacement, Remove mother board cover: 手順 4、 3の画像 3
    • Remove three screws under keyboard
    • Don't forget the security protocol we followed in step 1 and 2
    • Insert pry tool around the cover in which touchpad used to be until release
    • First release the left side because the right has a clips which hold the cover.
  5. HP 14-r008la Hard Disk Replacement, Remove HDD and insert another one: 手順 5、 3の画像 1 HP 14-r008la Hard Disk Replacement, Remove HDD and insert another one: 手順 5、 3の画像 2 HP 14-r008la Hard Disk Replacement, Remove HDD and insert another one: 手順 5、 3の画像 3
    • Release the connector to which the cable of two usb ports has been attaching
    • Remove the two usb ports and the speaker, and the two HDD screws then pull the HDD off
    • Remove metal frame in the first HDD and put it in the second
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Internet Libre
メンバー登録日: 01/15/15
718 ポイント
5のガイドは作成済み
コメント 1 件
Good job it did not work
Susan Oginni - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 21
今までの合計 4,705
