はじめに
In this guide, you will learn how to remove the HP 14-fq1025nr trackpad to replace it with a new one. The trackpad is used to move the mouse cursor. A faulty trackpad may result in the cursor not being moved at all. For additional information and help with troubleshooting the trackpad, refer to our troubleshooting page.
WARNING: The computer uses a lithium-ion battery which contains toxic substances / flammable substances. Handle with caution.
必要な工具と部品
Remove the four gray 3 mm screws holding down the battery using a Phillips #0 screwdriver.
Remove the six gray 2 mm screws around the trackpad using a Phillips #00 screwdriver.
