メインコンテンツにスキップ
HMDX Jam Plus Line In Jack Replacement
必要な工具と部品
  1. HMDX Jam Plus  Line In Jack Replacement, Battery: 手順 1、 3の画像 1 HMDX Jam Plus  Line In Jack Replacement, Battery: 手順 1、 3の画像 2 HMDX Jam Plus  Line In Jack Replacement, Battery: 手順 1、 3の画像 3
    • Flip the device over so the bottom is facing up.
    • Use the large plastic opening tool to gently pry the rubber base from the device.
    • Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
  2. HMDX Jam Plus  Line In Jack Replacement: 手順 2、 2の画像 1 HMDX Jam Plus  Line In Jack Replacement: 手順 2、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
  3. HMDX Jam Plus  Line In Jack Replacement: 手順 3、 2の画像 1 HMDX Jam Plus  Line In Jack Replacement: 手順 3、 2の画像 2
    • Gently separate the base from the rest of the device to reveal the battery and the main board.
  4. HMDX Jam Plus  Line In Jack Replacement: 手順 4、 3の画像 1 HMDX Jam Plus  Line In Jack Replacement: 手順 4、 3の画像 2 HMDX Jam Plus  Line In Jack Replacement: 手順 4、 3の画像 3
    • Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
    • Pull gently on the connectors to separate each one from the main board.
    • The battery is connected to board in the red socket and the speaker is connected in the white socket.
  5. HMDX Jam Plus  Line In Jack Replacement: 手順 5、 3の画像 1 HMDX Jam Plus  Line In Jack Replacement: 手順 5、 3の画像 2 HMDX Jam Plus  Line In Jack Replacement: 手順 5、 3の画像 3
    • Batteries can be very dangerous if punctured. Use extra caution when using tools around the battery.
    • Use the plastic opening tool to gently pry the battery free from the rest of the device.
  6. HMDX Jam Plus  Line In Jack Replacement: 手順 6、 2の画像 1 HMDX Jam Plus  Line In Jack Replacement: 手順 6、 2の画像 2
    • Use new adhesive to secure battery back to the rest of the device.
  7. HMDX Jam Plus  Line In Jack Replacement, Line In Jack: 手順 7、 2の画像 1 HMDX Jam Plus  Line In Jack Replacement, Line In Jack: 手順 7、 2の画像 2
    • Remove the three black 6mm screws from the main board using a Philips #00 screwdriver.
  8. HMDX Jam Plus  Line In Jack Replacement: 手順 8、 2の画像 1 HMDX Jam Plus  Line In Jack Replacement: 手順 8、 2の画像 2
    • Carefully lift the main board away from the plastic.
    • Lift the side with the buttons first and be careful not to damage the Line In Jack or the Micro USB Jack.
  9. HMDX Jam Plus  Line In Jack Replacement: 手順 9、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use the Micro soldering iron to heat up each pad and use the desoldering wick to wick up the melted solder.
    • The surface mount jack should pull from the surface without much force. Use tweezers to apply upward pressure on on the jack.
    • Do not apply too much heat to the board as it may damage other portions of the board.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Maxwell Erickson
メンバー登録日: 10/22/15
587 ポイント
4のガイドは作成済み
チーム
Montana Tech, Team 10-3, Shirk Fall 2015 Montana Tech, Team 10-3, Shirk Fall 2015人のメンバー
MTUM-SHIRK-F15S10G3
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 397
