はじめに
If the HMDX Chill begins to show issues with its ability to charge and the issue is not related to the charging port or charging cable it may be time to change the battery. This guide will show how to disassemble the device in order to locate and find the battery along with showing all of the attachments from the battery to the motherboard in order to properly replace the battery.
必要な工具と部品
Once the base has been removed from the rest of the speaker locate the battery.
Locate the wires that attaches from the battery to the motherboard.
Using a soldering iron desolder the wires from the motherboard.
ある他の人がこのガイドを完成しました。
