メインコンテンツにスキップ
Gyroscopic exercise tool (Powerball) Roller Fix
必要な工具と部品
  1. Gyroscopic exercise tool (Powerball) Roller Fix, Remove rubber band: 手順 1、 1の画像 1
    • Remove rubber band.
  2. Gyroscopic exercise tool (Powerball) Roller Fix, Unscrew holdings: 手順 2、 1の画像 1
    • Find two small Phillips screws holding both housing halves and unscrew them.
  3. Gyroscopic exercise tool (Powerball) Roller Fix, Split housing: 手順 3、 1の画像 1
    • Use some flat tool, I used small blade of my Swiss Army knife but spudger should be a better choice. Pry one half from the other. You will hear loud click and then it should open.
  4. Gyroscopic exercise tool (Powerball) Roller Fix, Open housing: 手順 4、 3の画像 1 Gyroscopic exercise tool (Powerball) Roller Fix, Open housing: 手順 4、 3の画像 2 Gyroscopic exercise tool (Powerball) Roller Fix, Open housing: 手順 4、 3の画像 3
    • Remove gyro. It’s connected to white plastic roundel which really is a part of inner bearing. It slides on the both sides of housing.
  5. Gyroscopic exercise tool (Powerball) Roller Fix, Identify deflections: 手順 5、 1の画像 1
    • Look at these surfaces and you will find several small deflections. They were made by gyro’s axis when it hit the floor. These deflections put up resistance during rolling and this is the reason it’s so hard to spin device.
  6. Gyroscopic exercise tool (Powerball) Roller Fix, Fill deflections with glue: 手順 6、 1の画像 1
    • You have to fill them with Superglue or other cyanoacrylate glue. Fill them and wait for around 20 minutes.
    • Caution: check if glue you use is OK, try it on some hidden area of housing.
  7. Gyroscopic exercise tool (Powerball) Roller Fix, Make it smooth: 手順 7、 1の画像 1
    • Use some sharp tool and remove surpluses, make these places as smooth as you can. From time to time put gyro back in place and roll it on both halves of housing until you’ll feel it’s enough.
  8. Gyroscopic exercise tool (Powerball) Roller Fix, Put it back: 手順 8、 1の画像 1
    • Put whole device back in reverse order and test it. The more you will spin it, the smoother it will work. The best thing is: you can fix it over and over again and you don’t have to pay again.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
paczor
メンバー登録日: 04/22/10
758 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 22
過去 30 日: 60
今までの合計 4,630
