メインコンテンツにスキップ
Guitar Nut Replacement
必要な工具と部品
  1. Guitar Nut Replacement, Guitar Nut: 手順 1、 2の画像 1 Guitar Nut Replacement, Guitar Nut: 手順 1、 2の画像 2
    • Turn the knobs to unwind all guitar strings currently on the guitar.
    • For this type of guitar turn the knobs on the right side clockwise and the left side counter-clockwise. Double-check this process by pulling the strings gently to see if the strings are losing tension.
  2. Guitar Nut Replacement: 手順 2、 2の画像 1 Guitar Nut Replacement: 手順 2、 2の画像 2
    • Cut around the guitar nut on the bottom and back side with a precision knife.
    • When cutting gently wedge the knife in using firm pressure, but using too much force may cause the knife to slip out.
  3. Guitar Nut Replacement: 手順 3、 1の画像 1
    • Pry out the guitar nut using the precision knife.
    • Guitars with older glue can cause the nut to pop out of the groove unexpectedly during this step.
  4. Guitar Nut Replacement: 手順 4、 1の画像 1
    • Sand away excess old glue in the groove of the guitar head.
    • Using the 80 grit sandpaper first is recommended, as this helps to remove tougher glue. Using the 120 grit sandpaper helps to smooth out the groove and eases laster steps.
  5. Guitar Nut Replacement: 手順 5、 2の画像 1 Guitar Nut Replacement: 手順 5、 2の画像 2
    • Sand the sides of the guitar nut until the guitar nut will fit in the grove of the guitar head.
    • Only the bottom and back of the new nut should be sanded.
  6. Guitar Nut Replacement: 手順 6、 2の画像 1 Guitar Nut Replacement: 手順 6、 2の画像 2
    • Glue in the guitar nut in the groove of the guitar head.
    • Glue may be placed on the groove of the guitar head or the bottom and the back of the guitar nut.
  7. Guitar Nut Replacement: 手順 7、 1の画像 1
    • Rewind the strings back through the new nut.
    • For this type of guitar, turn the knobs in the opposite direction as in Step 1. As you rewind the guitar, the strings should become tenser.
終わりに
Now that your guitar is repaired don’t forget to tune the guitar. The website https://guitar-tuner.org/ is an excellent resource for tuning your instrument.
作成者
3人の作成者と共同で作成されました。
Margaret Otto
メンバー登録日: 02/21/22
145 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 1-5, Smith Spring 2022 University of North Texas, Team 1-5, Smith Spring 2022人のメンバー
UNT-SMITH-S22S1G5
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 14
今までの合計 725
