はじめに
This guide will teach the user how to install the right side panel and align the buttons correctly. It will also focus on the restoration of functionality of the device and show the proper placement of the buttons to restore the device to its retail form.
パーツ
パーツは必要ありません。
  1. Use the plastic opening tool.
    • Use the plastic opening tool.
    • Lodge the tip into the corner of the device; Applying pressure upward, allowing the panel to be released.
    コメントを追加する
  2. The side panel can now be detached using your fingers.
    • The side panel can now be detached using your fingers.
    • The buttons can be dislodged by turning the panel over and shaking it, if necessary.
    コメントを追加する
  3. Fixmasのスピリットを広めましょう
    クーポンコードFIXMAS12を使えば、50ドル以上のお買い上げで12ドル割引となります。
    Fixmasのスピリットを広めましょう
    • Ensure that the elevated grating is on the left side of the button, as seen in the first posted image.
    • Insert the button with the sound diagrams to the top section of the panel.
    コメントを追加する
    • Ensure that the elevated grating is on the left side of the button, as seen in the posted image.
    • Insert the button with the two arrows to the bottom section of the panel.
    コメントを追加する
    • Be careful with handling the panel during placement. Utilize gravity to keep the buttons from falling out.
    • Using your fingers, carefully click in the bottom end of the panel, followed by the top end of the panel.
    コメントを追加する
    • Apply pressure to both side panels simultaneously to ensure the device has restored original stability.
    コメントを追加する
まとめ
After installation, the device should look similar to that which is depicted in the cover image (top right of page).
Alexander
メンバー登録日: 2012年03月09日
101 ポイント
9のガイドは作成済み
チーム
Clemson, Team 15-3, Benson Spring 2012 Clemson, Team 15-3, Benson Spring 2012人のメンバー
CLEM-BENSON-S12S15G3
3 メンバー
9のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 840
