はじめに
This guide will teach the user how to install the right side panel and align the buttons correctly. It will also focus on the restoration of functionality of the device and show the proper placement of the buttons to restore the device to its retail form.
パーツ
パーツは必要ありません。
  1. Use the plastic opening tool.
    • Use the plastic opening tool.
    • Lodge the tip into the corner of the device; Applying pressure upward, allowing the panel to be released.
  2. The side panel can now be detached using your fingers. The buttons can be dislodged by turning the panel over and shaking it, if necessary. The buttons can be dislodged by turning the panel over and shaking it, if necessary.
    • The side panel can now be detached using your fingers.
    • The buttons can be dislodged by turning the panel over and shaking it, if necessary.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Ensure that the elevated grating is on the left side of the button, as seen in the first posted image.
    • Ensure that the elevated grating is on the left side of the button, as seen in the first posted image.
    • Insert the button with the sound diagrams to the top section of the panel.
  5. Ensure that the elevated grating is on the left side of the button, as seen in the posted image.
    • Ensure that the elevated grating is on the left side of the button, as seen in the posted image.
    • Insert the button with the two arrows to the bottom section of the panel.
  6. Be careful with handling the panel during placement. Utilize gravity to keep the buttons from falling out.
    • Be careful with handling the panel during placement. Utilize gravity to keep the buttons from falling out.
    • Using your fingers, carefully click in the bottom end of the panel, followed by the top end of the panel.
  7. Apply pressure to both side panels simultaneously to ensure the device has restored original stability. Apply pressure to both side panels simultaneously to ensure the device has restored original stability.
    • Apply pressure to both side panels simultaneously to ensure the device has restored original stability.
まとめ
After installation, the device should look similar to that which is depicted in the cover image (top right of page).
Alexander
メンバー登録日: 2012年03月09日
101 ポイント
9のガイドは作成済み
チーム
Clemson, Team 15-3, Benson Spring 2012 Clemson, Team 15-3, Benson Spring 2012人のメンバー
CLEM-BENSON-S12S15G3
3 メンバー
9のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 841
