はじめに
Use this guide to replace the Greenwok 10A 16” Lawn Mower Starter Lever. To start the motor, this lawnmower requires a strong starter lever. However, the starter levers are easily broken because they are hollow and fragile; they may also be old and difficult to use. Replacing your starter lever will make it easier to use your lawnmower.
This guide provides step-by-step instructions to replace the starter lever of your lawnmower. Use caution when disassembling and reassembling your lawnmower, as some parts may be difficult to handle.
必要な工具と部品
As seen in the picture, the lever is snapped on one side and needs to be replaced.
Now that the lever is replaced, be careful when you pull the lever back and place the mower down. This will avoid future issues and another replacement.
1件のガイドコメント
I have a Greenwork 40 volt electric mower. I start it up correctly (first push down the start button, and as it is pushed down, then pull back on the starter lever. Suddenly, it shuts off now after 1 or 2 seconds. This occurs repeatedly and the mower is not operational. The two batteries are fully charged. Any suggestions?
v15venable - 返信 共有
