はじめに
To remove the mounting post, you must take out all internal parts in front of the mounting post. Push down on the spring that is holding the mounting post in place. When the spring is compressed, both the mounting post and the spring can be removed if you push them away from the outside casing.
必要な工具と部品
Flip the GravityLight on its back and place it on a sturdy surface.
Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
Firmly grasp both parts of the GravityLight body and pull them apart.
Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
Firmly grasp both parts of the back panel and pull them apart.
Place the middle section on a sturdy surface.
Move any wires in front of the mounting post.
Push down on the spring.
Push the spring and the mounting post away from the middle section and remove them from the pocket.
