メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Graco Secure Coverage LED Parent Unit Replacement
必要な工具と部品
    1. Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: 手順 1、 3の画像 1 Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: 手順 1、 3の画像 2 Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: 手順 1、 3の画像 3
      • Using plastic opening tool, pry and remove the battery lid.
      FixBotに聞いてみる
      コメントを追加
    2. Graco Secure Coverage LED Parent Unit Replacement: 手順 2、 1の画像 1
      • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
      • Make sure that you disconnect the battery's wire before you remove the battery.
      FixBotに聞いてみる
      コメントを追加
    1. Graco Secure Coverage LED Parent Unit Replacement, LED Parent Unit: 手順 3、 2の画像 1 Graco Secure Coverage LED Parent Unit Replacement, LED Parent Unit: 手順 3、 2の画像 2
      • There are two screws on the rare case of the device. For the one shown in blue marker requires either an extended screwdriver or putting on a little pressure on a regular screwdriver.
      • Remove the two 9mm Phillips #1 screws from the rare case of the device.
      • If you cannot remove the screw with low pressure, do not use high pressure to remove it. It may cause a damage on the device case. Use an extended screwdriver instead.
      FixBotに聞いてみる
      コメントを追加
    2. Graco Secure Coverage LED Parent Unit Replacement: 手順 4、 2の画像 1 Graco Secure Coverage LED Parent Unit Replacement: 手順 4、 2の画像 2
      • Using opening plastic tool, pry the two grey cases from both sides of the device.
      • Take your time and apply constant force to avoid breaking or damaging any other plastic parts.
      • While pry off the grey cases, hold the device with your other hand to remove the cases
      FixBotに聞いてみる
      コメントを追加
    3. Graco Secure Coverage LED Parent Unit Replacement: 手順 5、 1の画像 1
      • Pry the edges of the device to separate the front and rare cases.
      • While prying the edges, hold the device with one hand to pull out each case a part.
      • Make sure you use a constant force, and the pushbuttons are pried off completely.
      FixBotに聞いてみる
      コメントを追加
    4. Graco Secure Coverage LED Parent Unit Replacement: 手順 6、 2の画像 1 Graco Secure Coverage LED Parent Unit Replacement: 手順 6、 2の画像 2
      • Remove the 7mm Phillips #1 screw from the mother board.
      • Place the screw in a secure place.
      FixBotに聞いてみる
      コメントを追加
    5. Graco Secure Coverage LED Parent Unit Replacement: 手順 7、 2の画像 1 Graco Secure Coverage LED Parent Unit Replacement: 手順 7、 2の画像 2
      • Flip over the motherboard.
      • Solder off LED from motherboard.
      • There are many pins attached to the motherboard, make sure you solder off the proper pins that attached to the LED's.
      • Replace the LED's
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Bryson Wolff
メンバー登録日: 08/31/15
237 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 6-5, Remmell Fall 2015 USF Tampa, Team 6-5, Remmell Fall 2015人のメンバー
USFT-REMMELL-F15S6G5
4 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 24
今までの合計 394
