メインコンテンツにスキップ
Graco Secure Coverage LED Nursery Unit Replacement
必要な工具と部品
  1. Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: 手順 1、 3の画像 1 Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: 手順 1、 3の画像 2 Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: 手順 1、 3の画像 3
    • Remove the 9mm screw from the battery cover of the nursery unit using a Phillips #1 tip screwdriver.
  2. Graco Secure Coverage LED Nursery Unit Replacement: 手順 2、 2の画像 1 Graco Secure Coverage LED Nursery Unit Replacement: 手順 2、 2の画像 2
    • Using the plastic opening tool, pry and remove the battery cover carefully.
    • Remove the batteries using plastic opening tool.
    • Replace the batteries.
  3. Graco Secure Coverage LED Nursery Unit Replacement, LED Nursery Unit: 手順 3、 2の画像 1 Graco Secure Coverage LED Nursery Unit Replacement, LED Nursery Unit: 手順 3、 2の画像 2
    • Remove the two 9mm Phillips #1 screws from the rare case of the device.
    • Place the screws in a secure place.
  4. Graco Secure Coverage LED Nursery Unit Replacement: 手順 4、 1の画像 1
    • Hold the bottom of the device with one hand and pull down to separate the front and rare cases.
    • While holding the device with one hand, use plastic opening tool to pry the edges of the front case away from the back case.
    • Apply constant force carefully to avoid breaking any other plastic parts from the device.
  5. Graco Secure Coverage LED Nursery Unit Replacement: 手順 5、 2の画像 1 Graco Secure Coverage LED Nursery Unit Replacement: 手順 5、 2の画像 2
    • Remove all three 7mm Phillips #1 screws from the mother board.
    • Place the screws in secure place.
  6. Graco Secure Coverage LED Nursery Unit Replacement: 手順 6、 3の画像 1 Graco Secure Coverage LED Nursery Unit Replacement: 手順 6、 3の画像 2 Graco Secure Coverage LED Nursery Unit Replacement: 手順 6、 3の画像 3
    • Flip over the motherboard to look at the LED pins that are connected to it.
    • Solder off the LED pin from the motherboard.
    • There are many pins are connect to the motherboard, so make sure that you solder off the LED pin.
    • Replace the LED.
終わりに
作成者
2人の作成者と共同で作成されました。
Bryson Wolff
メンバー登録日: 08/31/15
237 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 6-5, Remmell Fall 2015 USF Tampa, Team 6-5, Remmell Fall 2015人のメンバー
USFT-REMMELL-F15S6G5
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 142
