メインコンテンツにスキップ
Google Pixelbook Right Charging Port Replacement
必要な工具と部品
  1. Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): 手順 1、 3の画像 1 Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): 手順 1、 3の画像 2 Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): 手順 1、 3の画像 3
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
  2. Google Pixelbook Right Charging Port Replacement: 手順 2、 2の画像 1 Google Pixelbook Right Charging Port Replacement: 手順 2、 2の画像 2
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
  3. Google Pixelbook Right Charging Port Replacement: 手順 3、 3の画像 1 Google Pixelbook Right Charging Port Replacement: 手順 3、 3の画像 2 Google Pixelbook Right Charging Port Replacement: 手順 3、 3の画像 3
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
  4. Google Pixelbook Right Charging Port Replacement: 手順 4、 3の画像 1 Google Pixelbook Right Charging Port Replacement: 手順 4、 3の画像 2 Google Pixelbook Right Charging Port Replacement: 手順 4、 3の画像 3
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
  5. Google Pixelbook Right Charging Port Replacement: 手順 5、 2の画像 1 Google Pixelbook Right Charging Port Replacement: 手順 5、 2の画像 2
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
  6. Google Pixelbook Right Charging Port Replacement: 手順 6、 2の画像 1 Google Pixelbook Right Charging Port Replacement: 手順 6、 2の画像 2
    • Remove the small, black casing by using the spudger to lift it up from its place.
  7. Google Pixelbook Right Charging Port Replacement: 手順 7、 1の画像 1
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
  8. Google Pixelbook Right Charging Port Replacement, Right Charging Port: 手順 8、 2の画像 1 Google Pixelbook Right Charging Port Replacement, Right Charging Port: 手順 8、 2の画像 2
    • Remove the three 2.0mm black screws from the sound card by using a T5 Torx screwdriver to turn them counterclockwise.
    • Remove the gold 3.0mm screw by using a T3 Torx screwdriver to turn it counterclockwise.
  9. Google Pixelbook Right Charging Port Replacement: 手順 9、 1の画像 1
    • Disconect the thin, black and red cord from the motherboard by using the spudger to snap the connector up and out of place.
  10. Google Pixelbook Right Charging Port Replacement: 手順 10、 1の画像 1
    • Remove the yellow 2.0mm screw by using the T3 Torx screwdriver to turn the screw counterclockwise.
  11. Google Pixelbook Right Charging Port Replacement: 手順 11、 1の画像 1
    • Remove the small, red component by lifting it up with the spudger.
  12. Google Pixelbook Right Charging Port Replacement: 手順 12、 1の画像 1
    • Disconnect the metal component of the thin, black component by lifting it up with the spudger.
  13. Google Pixelbook Right Charging Port Replacement: 手順 13、 2の画像 1 Google Pixelbook Right Charging Port Replacement: 手順 13、 2の画像 2
    この手順で使用する道具:
    購入する
    • Remove the right charging port by picking it up with the tweezers and lifting it from the computer.
終わりに
作成者
4人の作成者と共同で作成されました。
Alon Gary
メンバー登録日: 01/24/18
556 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S18-G1, Livingston Winter 2018 Cal Poly, Team S18-G1, Livingston Winter 2018人のメンバー
CPSU-LIVINGSTON-W18S18G1
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 17
今までの合計 1,626
