メインコンテンツにスキップ
Google Pixel Slate Speaker Replacement
必要な工具と部品
  1. Google Pixel Slate Speaker Replacement, Screen: 手順 1、 3の画像 1 Google Pixel Slate Speaker Replacement, Screen: 手順 1、 3の画像 2 Google Pixel Slate Speaker Replacement, Screen: 手順 1、 3の画像 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Speaker Replacement: 手順 2、 3の画像 1 Google Pixel Slate Speaker Replacement: 手順 2、 3の画像 2 Google Pixel Slate Speaker Replacement: 手順 2、 3の画像 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Speaker Replacement, Speaker: 手順 3、 3の画像 1 Google Pixel Slate Speaker Replacement, Speaker: 手順 3、 3の画像 2 Google Pixel Slate Speaker Replacement, Speaker: 手順 3、 3の画像 3
    • There are two speakers, one on each side of the Google Pixel Slate. This guide works for either one.
    • Use the T2 Torx screwdriver to remove the yellow 2mm screw from the thin metal plate.
    • Use the T3 Torx screwdriver to remove the pink 3mm screw from the thin metal plate.
    • Remove the thin metal plate from the device.
  4. Google Pixel Slate Speaker Replacement: 手順 4、 1の画像 1
    • Use the T2 Torx screwdriver to remove the two black 2mm screws from the speaker.
  5. Google Pixel Slate Speaker Replacement: 手順 5、 2の画像 1 Google Pixel Slate Speaker Replacement: 手順 5、 2の画像 2
    • Use the Nylon-Tipped Tweezers to remove the black plug.
    • There is a red and a black wire connected to the black plug.
    • Pull the black plug in an upwards direction.
    • Be sure to gently remove plug, as using too much force can damage the connecting wires.
  6. Google Pixel Slate Speaker Replacement: 手順 6、 2の画像 1 Google Pixel Slate Speaker Replacement: 手順 6、 2の画像 2
    • Use the Nylon-Tipped Tweezers to disconnect the black tape-like plug connected to the speaker.
  7. Google Pixel Slate Speaker Replacement: 手順 7、 2の画像 1 Google Pixel Slate Speaker Replacement: 手順 7、 2の画像 2
    • Detach the speaker wire from the motherboard.
    • Remove the adhesive strips that hold down the speaker wire.
  8. Google Pixel Slate Speaker Replacement: 手順 8、 3の画像 1 Google Pixel Slate Speaker Replacement: 手順 8、 3の画像 2 Google Pixel Slate Speaker Replacement: 手順 8、 3の画像 3
    • Use the T2 Torx screwdriver to remove the 2mm black screw from the brass plate.
    • Pull back the brass plate.
  9. Google Pixel Slate Speaker Replacement: 手順 9、 1の画像 1
    • You can now remove the speaker from the device.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Spencer Alonge
メンバー登録日: 04/18/19
648 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S2-G5, Maness Spring 2019 Cal Poly, Team S2-G5, Maness Spring 2019人のメンバー
CPSU-MANESS-S19S2G5
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 8
今までの合計 873
