メインコンテンツにスキップ
Google Pixel Slate Front-Facing Camera Replacement
必要な工具と部品
  1. Google Pixel Slate Front-Facing Camera Replacement, Screen: 手順 1、 3の画像 1 Google Pixel Slate Front-Facing Camera Replacement, Screen: 手順 1、 3の画像 2 Google Pixel Slate Front-Facing Camera Replacement, Screen: 手順 1、 3の画像 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Front-Facing Camera Replacement: 手順 2、 3の画像 1 Google Pixel Slate Front-Facing Camera Replacement: 手順 2、 3の画像 2 Google Pixel Slate Front-Facing Camera Replacement: 手順 2、 3の画像 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: 手順 3、 3の画像 1 Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: 手順 3、 3の画像 2 Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: 手順 3、 3の画像 3
    • Once removed, place the screen face down.
    • Peel back the black, adhesive strip covering the front camera so that the silver plate is exposed.
  4. Google Pixel Slate Front-Facing Camera Replacement: 手順 4、 3の画像 1 Google Pixel Slate Front-Facing Camera Replacement: 手順 4、 3の画像 2 Google Pixel Slate Front-Facing Camera Replacement: 手順 4、 3の画像 3
    • Hold back the adhesive tape to expose the two black 2mm screws that are holding down the cover plate.
    • Use the T2 Torx screwdriver to remove the two 2mm screws.
  5. Google Pixel Slate Front-Facing Camera Replacement: 手順 5、 2の画像 1 Google Pixel Slate Front-Facing Camera Replacement: 手順 5、 2の画像 2
    • Once the two 2mm screws are removed, lift and remove the cover plate.
  6. Google Pixel Slate Front-Facing Camera Replacement: 手順 6、 2の画像 1 Google Pixel Slate Front-Facing Camera Replacement: 手順 6、 2の画像 2
    • Pull upwards on the flat wire to remove the front-facing camera from the device.
    • The camera may be secured to the screen body with adhesive tape. Apply gentle force to remove the camera by removing the tape.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Spencer Alonge
メンバー登録日: 04/18/19
648 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S2-G5, Maness Spring 2019 Cal Poly, Team S2-G5, Maness Spring 2019人のメンバー
CPSU-MANESS-S19S2G5
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 12
今までの合計 799
