メインコンテンツにスキップ
Google Pixel C Headphone Jack Replacement
必要な工具と部品
  1. Google Pixel C Headphone Jack Replacement, Screen: 手順 1、 1の画像 1
    • Ensure that the device is completely powered down before beginning to take it apart
    • Use a heat gun to melt the adhesive that holds the screen to the device
    • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
    • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
  2. Google Pixel C Headphone Jack Replacement: 手順 2、 2の画像 1 Google Pixel C Headphone Jack Replacement: 手順 2、 2の画像 2
    • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
    • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
    • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
    • Reattaching the screen will require adhesive to ensure that it stays in place.
  3. Google Pixel C Headphone Jack Replacement: 手順 3、 2の画像 1 Google Pixel C Headphone Jack Replacement: 手順 3、 2の画像 2
    • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
  4. Google Pixel C Headphone Jack Replacement: 手順 4、 2の画像 1 Google Pixel C Headphone Jack Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    購入する
    • Follow the same removal procedure to detach the wide gold cable.
    • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
    • This device is missing a battery, so the device that you are working on may appear slightly different inside.
  5. Google Pixel C Headphone Jack Replacement, Headphone Jack: 手順 5、 1の画像 1
    • Orient the device so that the headphone jack is in the bottom right corner.
  6. Google Pixel C Headphone Jack Replacement: 手順 6、 2の画像 1 Google Pixel C Headphone Jack Replacement: 手順 6、 2の画像 2
    • Remove the two 3.5mm Phillips #000 screws.
  7. Google Pixel C Headphone Jack Replacement: 手順 7、 1の画像 1
    • Locate and remove the two 2.5mm Phillips #000 screws on either side of the wire coil.
  8. Google Pixel C Headphone Jack Replacement: 手順 8、 2の画像 1 Google Pixel C Headphone Jack Replacement: 手順 8、 2の画像 2
    • Detach the red and black cable using a narrow spudger.
  9. Google Pixel C Headphone Jack Replacement: 手順 9、 2の画像 1 Google Pixel C Headphone Jack Replacement: 手順 9、 2の画像 2
    • Detach the cable connecting to the headphone jack.
  10. Google Pixel C Headphone Jack Replacement: 手順 10、 2の画像 1 Google Pixel C Headphone Jack Replacement: 手順 10、 2の画像 2
    • Lift the headphone jack, coiled wire, and cable, peeling the adhesive back.
    • Reassembly will require adhesive to ensure that the components are secured to the device.
終わりに
作成者
1人の作成者と共同作成されました。
Deborah Iwakiri
メンバー登録日: 04/25/17
522 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S21-G4, Livingston Spring 2017 Cal Poly, Team S21-G4, Livingston Spring 2017人のメンバー
CPSU-LIVINGSTON-S17S21G4
4 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 979
