はじめに
Use this guide to remove and replace the battery in a Google Pixel 5a. If you are experiencing a reduced battery life on your Google Pixel 5a you may need to replace the battery. The battery in this budget smartphone may need to be replaced after extended use. Please properly dispose of the old battery.
Before starting the guide turn off your device.
必要な工具と部品
Shut down the device before starting screen removal.
Insert a paper clip or SIM card removal tool into the SIM card tray hole.
Apply a small amount of pressure until the tray pops out.
Slide the SIM card tray out of your Google Pixel 5a.
ある他の人がこのガイドを完成しました。
