メインコンテンツにスキップ
Google Pixel 2 Opening Procedure
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. Google Pixel 2 Opening Procedure, Opening Procedure: 手順 1、 2の画像 1 Google Pixel 2 Opening Procedure, Opening Procedure: 手順 1、 2の画像 2
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. This also makes a smooth surface allowing the suction cup to bond.
    • Apply a suction cup as close to the volume button edge of the phone as you can while avoiding the curved edge.
    • The suction cup will not make a good seal on the curved portion of the glass.
  2. Google Pixel 2 Opening Procedure: 手順 2、 3の画像 1 Google Pixel 2 Opening Procedure: 手順 2、 3の画像 2 Google Pixel 2 Opening Procedure: 手順 2、 3の画像 3
    • Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
    • This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener, heat gun, or hair dryer.
  3. Google Pixel 2 Opening Procedure: 手順 3、 2の画像 1 Google Pixel 2 Opening Procedure: 手順 3、 2の画像 2
    • In the following steps, extra caution is required in certain areas to avoid damage to the phone:
    • Do not insert the pick more than 0.5 inches into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel it can damage the display.
    • Only make very shallow cuts in the upper left corner, prying deeply can damage the front-facing camera.
  4. Google Pixel 2 Opening Procedure: 手順 4、 2の画像 1 Google Pixel 2 Opening Procedure: 手順 4、 2の画像 2
    • In the following steps, use the flat of the opening pick, rather than a corner, to cut here. This will help prevent inserting the pick too deeply.
    • Slide the opening pick up the right side of the phone to separate the display adhesive.
  5. Google Pixel 2 Opening Procedure: 手順 5、 3の画像 1 Google Pixel 2 Opening Procedure: 手順 5、 3の画像 2 Google Pixel 2 Opening Procedure: 手順 5、 3の画像 3
    • Slide the opening pick around the upper-right corner and along the top edge of the phone.
  6. Google Pixel 2 Opening Procedure: 手順 6、 3の画像 1 Google Pixel 2 Opening Procedure: 手順 6、 3の画像 2 Google Pixel 2 Opening Procedure: 手順 6、 3の画像 3
    • Slide the pick around the upper-left corner of the phone and down the left edge of the phone.
  7. Google Pixel 2 Opening Procedure: 手順 7、 3の画像 1 Google Pixel 2 Opening Procedure: 手順 7、 3の画像 2 Google Pixel 2 Opening Procedure: 手順 7、 3の画像 3
    • Slide the pick around the bottom-left corner and along the bottom of the phone. Keep pick at a slight angle away from the screen to avoid damage to the OLED corners.
  8. Google Pixel 2 Opening Procedure: 手順 8、 2の画像 1 Google Pixel 2 Opening Procedure: 手順 8、 2の画像 2
    • Reinsert the pick at the top edge of the phone and gently pry up the display.
    • If the display doesn't readily lift, do some extra prying to separate the last of the adhesive. The adhesive near the upper speaker is thicker than other places.
    • Don't try to fully separate the display yet, as a fragile ribbon cable still connects it to the phone's motherboard.
  9. Google Pixel 2 Opening Procedure: 手順 9、 2の画像 1 Google Pixel 2 Opening Procedure: 手順 9、 2の画像 2
    • Carefully lay the display down on top of the rear case as shown, making sure not to crease or tear the display ribbon cable.
    • Remove the two 4.0 mm T5 Torx screws securing the display cable bracket.
  10. Google Pixel 2 Opening Procedure: 手順 10、 1の画像 1
    • Remove the display cable bracket.
  11. Google Pixel 2 Opening Procedure: 手順 11、 2の画像 1 Google Pixel 2 Opening Procedure: 手順 11、 2の画像 2
    • Use the point of a spudger to lift the display cable connector up and out of its socket on the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • If any part of your screen doesn't respond to touch after your repair re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
    • During reassembly, pause here and replace the adhesive around the edges of the display.
終わりに
作成者
8人の作成者と共同で作成されました。
Adam O'Camb
メンバー登録日: 04/11/15
196,215 ポイント
416のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 308
