はじめに
Use this guide to replace the worn-out battery in your Google Pixel 2.
Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
Warning: Because of the strong adhesive securing the display, minimal clearance for inserting your tools, and high heat required, there is a good chance of accidentally damaging your display during this procedure. Unless you plan to replace your display in conjunction with this repair, work very carefully and be prepared to replace the display, should it not work upon reassembly. Follow the instructions carefully and observe all warnings to increase your odds of success.
If your battery is swollen, take appropriate precautions. Do not heat your phone. If needed, you can use a dropper or syringe to inject isopropyl alcohol (90+%) around the edges of the back cover to weaken the adhesive. Swollen batteries can be very dangerous, so wear eye protection and exercise due caution, or take it to a professional if you’re not sure how to proceed.
必要な工具と部品
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. This also makes a smooth surface allowing the suction cup to bond.
Apply a suction cup as close to the volume button edge of the phone as you can while avoiding the curved edge.
Apply a heated iOpener to the proximity sensor on the top edge of the midframe for two minutes to soften its adhesive.
If available, apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
Alternatively, apply a heated iOpener to the back of the phone over the battery for at least two minutes. Reheat and reapply the iOpener as needed until the battery adhesive is sufficiently weakened.
Hold the charging assembly cable out of the way and insert an opening pick along the bottom edge of the battery.
Apply steady, even pressure to slowly lever the battery up and out of the phone.
Only pry from the center of the battery to avoid damaging the delicate ribbon cables beneath either side of the battery.
この手順で使用する道具:Tesa 61395 Tape$5.99
Remove the battery.
Use a spudger to scrape away any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone, not directly onto the battery. The adhesive should not touch any of the cables under the battery.
Press the battery firmly into place for 20-30 seconds.
After completing this guide, calibrate your newly-installed battery.
91 の人々がこのガイドを完成させました。
38 件のコメント
The instructions say “No parts required” and yet I believe that for a battery replacement you might possibly require a new battery (and maybe a new screen in the case of a broken screen). Also you might suggest replacement adhesive and where to find that, too.
Hey. So I bought a new housing and a new screen for my Pixel 2. And I have a problem with that. After moving the parts to the new housing my vibromotor stopped working and bottom of the screen easily comes off. What should I do?
Hi Rauf, it’s hard to say exactly what’s wrong, but as a start I would disconnect and reconnect the vibrator motor to make sure it’s connected correctly. As for the screen, make sure you carefully clean any old adhesive off the screen and case (use 90% or higher isopropyl alcohol for stubborn), and apply new adhesive to the screen before you replace it. That should help the display seat in the case and stay put.
I have a quick question, if we were to replace the screen adhesive with the Tesa 61395 tape, would the phone still remain water resistant to IP67? I am only worried it would not hold it as strong as the original adhesive
Hi Tony, Tesa tape creates a strong bond and should secure your screen just as well as the old adhesive. Unfortunately, the phone won’t be waterproof since you can’t create a continuous seal using the tape.
