メインコンテンツにスキップ
Google Home Motherboard Replacement
必要な工具と部品
  1. Google Home Motherboard Replacement, Interconnect Cable: 手順 1、 3の画像 1 Google Home Motherboard Replacement, Interconnect Cable: 手順 1、 3の画像 2 Google Home Motherboard Replacement, Interconnect Cable: 手順 1、 3の画像 3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home Motherboard Replacement: 手順 2、 1の画像 1
    • Carefully remove the interconnect cable using a pair of tweezers.
  3. Google Home Motherboard Replacement, Mute Button Switch: 手順 3、 2の画像 1 Google Home Motherboard Replacement, Mute Button Switch: 手順 3、 2の画像 2
    • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
  4. Google Home Motherboard Replacement: 手順 4、 2の画像 1 Google Home Motherboard Replacement: 手順 4、 2の画像 2
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
    • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
  5. Google Home Motherboard Replacement, Motherboard: 手順 5、 2の画像 1 Google Home Motherboard Replacement, Motherboard: 手順 5、 2の画像 2
    • Disconnect the foam-padded, red and black cable that connects the motherboard to the sound driver, by squeezing and pulling on the tab
    • Disconnect the orange interconnect cable that connects the bottom of the device to the motherboard by pulling straight out on the orange tab.
  6. Google Home Motherboard Replacement: 手順 6、 2の画像 1 Google Home Motherboard Replacement: 手順 6、 2の画像 2
    • Using a Torx T6 screwdriver head, unscrew the five silver 1.7mm Torx screws keeping the motherboard in place.
    • Remove the motherboard.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Maya Wharton
メンバー登録日: 04/17/18
175 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S24-G11, Maness Spring 2018 Cal Poly, Team S24-G11, Maness Spring 2018人のメンバー
CPSU-MANESS-S18S24G11
4 メンバー
5のガイドは作成済み
2 件のコメント
Where can one purchase a replacement motherboard?
Jim Pflasterer - 返信
Most likely the only place to do so would be through contacting Google, as there is no parts sold at retail, only full units
Nick Bergstrom -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 20
今までの合計 3,152
