メインコンテンツにスキップ
GoPro Karma Arms Replacement
必要な工具と部品
  1. GoPro Karma Arms Replacement, Battery: 手順 1、 1の画像 1
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Arms Replacement, Stabilizer: 手順 2、 3の画像 1 GoPro Karma Arms Replacement, Stabilizer: 手順 2、 3の画像 2 GoPro Karma Arms Replacement, Stabilizer: 手順 2、 3の画像 3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Arms Replacement: 手順 3、 1の画像 1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Arms Replacement, Landing Gear: 手順 4、 1の画像 1
    • Flip the drone upside down with the landing gear out.
    • Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
  5. GoPro Karma Arms Replacement: 手順 5、 1の画像 1
    • Push with your thumb and pull up with your fingers to remove the landing gear.
    • Caution: The landing gear is connected by a thin cable so do not pull too far away.
  6. GoPro Karma Arms Replacement: 手順 6、 2の画像 1 GoPro Karma Arms Replacement: 手順 6、 2の画像 2
    • Flip over the landing gear and locate the cable connector.
    • Use your thumbnail to disconnect the cable and free the landing gear.
  7. GoPro Karma Arms Replacement, Arms: 手順 7、 1の画像 1
    • Remove the two 1.2 cm long hex screws with a Hex 2.0 screwdriver and set them aside.
  8. GoPro Karma Arms Replacement: 手順 8、 2の画像 1 GoPro Karma Arms Replacement: 手順 8、 2の画像 2
    • Remove both locked connectors by pushing the connector release tool into the hole in the center and pulling up with the white handles.
    • The connector release tool is only included with the purchase of a replacement arm from the GoPro website.
    • If you do not have a connector release tool, use a small screwdriver to push each tab while pulling up with the white handles.
  9. GoPro Karma Arms Replacement: 手順 9、 3の画像 1 GoPro Karma Arms Replacement: 手順 9、 3の画像 2 GoPro Karma Arms Replacement: 手順 9、 3の画像 3
    • Remove the cover plate by pulling up on the side.
    • Feed each connector through the hole and set aside the cover plate.
  10. GoPro Karma Arms Replacement: 手順 10、 2の画像 1 GoPro Karma Arms Replacement: 手順 10、 2の画像 2
    • Loosen the 2 cm long hex screw in the arm with a Hex 2.0 screwdriver.
    • The screw will not come out but loosen it until it can rotate easily.
    • Pull up and off the broken arm.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Kyle Hoff
メンバー登録日: 04/23/18
141 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S25-G14, Maness Spring 2018 Cal Poly, Team S25-G14, Maness Spring 2018人のメンバー
CPSU-MANESS-S18S25G14
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 2,239
