はじめに
Replacing an arm on the Karma can be done in less than 20 minutes. There are four main steps: removing the landing gear, removing the old arm, installing the new arm, reattaching the landing gear. This video will walk you through each step.
必要な工具と部品
ビデオインストラクション
もう少しです!
終わりに
3 の人々がこのガイドを完成させました。
3 件のコメント
Juste merci !
cedricgaeta - 返信
Can someone tell me what tools are needed? I’m looking first to see if I can repait a slightly cracked arm before needing to replace?
lenodski - 返信
The only tool needed is a 2.5mm hex key.
Blake Klein -
