メインコンテンツにスキップ
GoPro Hero5 Black Back Housing Replacement
必要な工具と部品
  1. GoPro Hero5 Black Back Housing Replacement, Battery: 手順 1、 3の画像 1 GoPro Hero5 Black Back Housing Replacement, Battery: 手順 1、 3の画像 2 GoPro Hero5 Black Back Housing Replacement, Battery: 手順 1、 3の画像 3
    • While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
  2. GoPro Hero5 Black Back Housing Replacement: 手順 2、 3の画像 1 GoPro Hero5 Black Back Housing Replacement: 手順 2、 3の画像 2 GoPro Hero5 Black Back Housing Replacement: 手順 2、 3の画像 3
    • Grab the plastic flap on the battery and pull the battery out.
  3. GoPro Hero5 Black Back Housing Replacement, Back Housing: 手順 3、 2の画像 1 GoPro Hero5 Black Back Housing Replacement, Back Housing: 手順 3、 2の画像 2
    • Pull and twist the lens cover right or left until it pops off.
    • The lens cover is secured tightly and might be difficult to twist off.
  4. GoPro Hero5 Black Back Housing Replacement: 手順 4、 1の画像 1
    • This step is not necessary but will make the process of removing the faceplate much easier.
    • Refer to the iOpener instructions for how to heat up and use the iOpener.
    • Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
    • The heated iOpener is very hot and can burn your hands. Avoid burns by using towels or gloves to hold the iOpener.
  5. GoPro Hero5 Black Back Housing Replacement: 手順 5、 3の画像 1 GoPro Hero5 Black Back Housing Replacement: 手順 5、 3の画像 2 GoPro Hero5 Black Back Housing Replacement: 手順 5、 3の画像 3
    • Starting with the edges, use the spudger to pry off the faceplate.
    • The faceplate is held down with adhesive and may take a while to get off.
  6. GoPro Hero5 Black Back Housing Replacement: 手順 6、 2の画像 1 GoPro Hero5 Black Back Housing Replacement: 手順 6、 2の画像 2
    • Remove the six T3 Torx screws.
  7. GoPro Hero5 Black Back Housing Replacement: 手順 7、 3の画像 1 GoPro Hero5 Black Back Housing Replacement: 手順 7、 3の画像 2 GoPro Hero5 Black Back Housing Replacement: 手順 7、 3の画像 3
    • Be careful when pulling open the motherboard assembly as it is still connected to the back housing by four cables. The cables may break if stretched.
    • Using the spudger, slowly pry open the motherboard assembly from the LCD side of the GoPro.
  8. GoPro Hero5 Black Back Housing Replacement: 手順 8、 3の画像 1 GoPro Hero5 Black Back Housing Replacement: 手順 8、 3の画像 2 GoPro Hero5 Black Back Housing Replacement: 手順 8、 3の画像 3
    • Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard.
  9. GoPro Hero5 Black Back Housing Replacement: 手順 9、 2の画像 1 GoPro Hero5 Black Back Housing Replacement: 手順 9、 2の画像 2
    • Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard.
終わりに
16 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Christopher Adams
メンバー登録日: 10/03/16
2,112 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 18-6, Forte Fall 2016 Cal Poly, Team 18-6, Forte Fall 2016人のメンバー
CPSU-FORTE-F16S18G6
4 メンバー
22のガイドは作成済み
2 件のコメント
Where can you get replacement rear screens for this
ociaravella - 返信
Hi, how i reset firmware in this gopro? I have a problem with a bucle starting and it dont turn on, always restarting.
ISU AREY - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 33
過去 30 日: 120
今までの合計 23,267
